Author Topic: Molex connection and Cable  (Read 2694 times)
Blueic5
  • Last login:December 16, 2018, 05:31:20 pm
« on: January 19, 2015, 05:50:27 pm »
How are people making long 12v molex cables?   Do you simply extend an exciting cable from the psu or can you make up your own from scratch?
Re: Molex connection and Cable
« Reply #1 on: January 19, 2015, 06:12:56 pm »
I just use my set of cable stretchers. Got em for a steal off amazon a while back.
« Reply #2 on: January 19, 2015, 06:49:26 pm »
Splice in two wires and roll your own.
Louis Tully
« Reply #3 on: January 19, 2015, 06:58:34 pm »
« Last Edit: February 12, 2015, 07:11:57 pm by Louis Tully »
Blueic5
« Reply #4 on: January 20, 2015, 05:44:11 am »
yes I was talking about standard molex connectors from PC PSU.  I thought I maybe able to make a female one up somehow but not finding the bits I would need when I looked and not sure where to start.
jdbailey1206
« Reply #5 on: January 20, 2015, 10:36:06 am »
Go to digikey dot com.  If you know what kind of connector you need they are a good place to start.  They have A LOT of stuff.  And if you dont know the name of the connector you need post a pic on here and someone (most likely PL1 (Scott)) can name it for you.  Fun fact: Did you know PL1 was birthed from the internet?
lamprey
« Reply #6 on: January 20, 2015, 05:53:25 pm »
Some people make them. Some People buy them.
I thought about making my own, but I only needed a couple and figured the time, effort and tools would be more than just buying a couple. So, I bought some like this:
http://www.amazon.com/inch-Molex-Extension-Cable-Sleeved/dp/B0014XDBIA
yeah, yeah I know it's a BYO site.. but hey..
bchiarmonte
  • Last login:November 05, 2016, 03:51:33 pm
« Reply #7 on: January 21, 2015, 02:26:53 am »
Most of the time buying one is the best option. Crimping them can be a pain in and it's just easier to buy one, and if you need it longer, just cut and solder/splice in an extension.
12v is yellow, 5v is red.
Blueic5
« Reply #8 on: January 21, 2015, 06:33:56 am »
that looks perfect but amazon uk to not seem to have anything that long :( ill keep hunting
lamprey
« Reply #9 on: January 21, 2015, 11:33:36 am »
Does Amazon not ship to the UK or charge a lot?
Just curious as I order movies from Amazon UK every so often without any issues, but you never know if the opposite is true.. :)
JDFan
« Reply #10 on: January 21, 2015, 01:07:04 pm »
THey do have 36 inch extensions on Amazon.uk.com ( http://www.amazon.co.uk/Phobya-900mm-Molex-Ultra-Extension/dp/B00EUREU8M/ref=sr_1_24?s=computers&ie=UTF8&qid=1421863441&sr=1-24&keywords=4+pin+molex+extension ) but they are a bit more expensive - EBAY UK has similar cheaper.
EBAY UK has 90cm ones for £3.69 (Can't tell what the shipping is as they just post does not post to U.S. when I look !!) ( http://www.ebay.co.uk/itm/90cm-4-pin-Molex-Power-Extension-Cable-Black-Sleeved-Extra-Tidy-/190946935025 )
« Last Edit: January 21, 2015, 01:17:29 pm by JDFan »
Blueic5
« Reply #11 on: January 21, 2015, 02:33:03 pm »
EBay ones are free shipping in UK too :),  was hoping for a little longer though
JDFan
« Reply #12 on: January 21, 2015, 03:43:05 pm »
Could always connect 2 together to make one longer one !
EDIT : Actually just thought of something -- went back to their listing and clicked on the store front to see other listings and this came up as one of the 10 Molex cable options  : ( http://www.ebay.co.uk/itm/72-Inch-Molex-4-Pin-LP4-Power-Extension-Cable-Black-Sleeved-/191137381808?pt=UK_Computing_Drive_Cables_Adapters&hash=item2c80acfdb0 )
72 Inch for £4.49 !!
« Last Edit: January 21, 2015, 03:47:54 pm by JDFan »
liquid134
  • Last login:February 15, 2018, 07:58:20 pm
« Reply #13 on: January 21, 2015, 10:18:41 pm »
if its just 4-pin molex connectors, i find it easier and neater to just crimp my own extensions. if you have the right crimper, and pins to go with the molex, its pretty easy.
Blueic5
« Reply #14 on: January 22, 2015, 08:32:48 am »
nice find thanks
gameroomsolutions
  • Last login:August 30, 2016, 02:08:54 pm
« Reply #15 on: January 26, 2015, 03:56:35 pm »
We sell 12v molex daisy chains for lighting up buttons.
http://gameroomsolutions.com/product/led-button-power-harness/
