Author Topic: FS: Pac or Ms Pac Cocktail CP light shields - $14/set shipped  (Read 1352 times)
shardian
« on: January 19, 2015, 03:01:40 pm »
Brand new 1/8" white acrylic cut to size for either cabinet.
I have 4 sets of Pacman light shields and 5 sets of Ms. Pac light shields.
$14 shipped per set (2 pieces) - cheaper if buying more than one set as they will ship together.
Mounting holes are not drilled, but I can drill the pac ones from an existing OEM shield as a template if you don't mind my "chippy" drill work. I don't have a working example to drill the Ms. Pac pieces.
« Last Edit: January 20, 2015, 02:47:34 pm by shardian »
Re: FS: Pac or Ms Pac Cocktail CP light shields - $14/set shipped
« Reply #1 on: January 20, 2015, 02:36:31 pm »
Welcome back!
Is it $14 a set?
Nevermind I see that in your original post.
Hoopz
  • Last login:January 24, 2026, 09:24:43 am
  • Intellivision Rocks!
« Reply #2 on: January 20, 2015, 02:38:24 pm »
You're alive!  Good to see you back.
shardian
« Reply #3 on: January 20, 2015, 02:52:02 pm »
Haha thanks guys.
I clarified the original post.
I had these made by a local acrylics manufacturer because I have waited months and months on two occasions for arcade parts vendors to get them in stock without luck. The last time I ended up buying used shields.
shardian
« Reply #4 on: January 20, 2015, 03:12:57 pm »
Likely hit n run. Sorry. I participate some on Facebook with the mid-Atlantic arcade collectors group, but no forums anymore.
Just wanted to share a need I figured might need filled.
shardian
« Reply #5 on: June 17, 2015, 11:21:53 pm »
Still have plenty of these
