Author Topic: I need a Popeye Harness  (Read 1210 times)
johnrt
« on: January 12, 2015, 01:39:14 pm »
Anyone know where I can find a Popeye harness? (None on ebay for the moment). Or a JAMMA adapter for that board. Is it the same connector/harness for all the Nintendo boards? (DK, Mario Bros...)
JDFan
Re: I need a Popeye Harness
« Reply #1 on: January 12, 2015, 02:30:42 pm »
There is a pdf copy of the manual which has the wiring diagram on page 16 available ( https://archive.org/details/popeyeoperationmanualtpp2-uptpp2-up-us ) that might help.
johnrt
« Reply #2 on: January 12, 2015, 04:50:33 pm »
Thanks for the link!
I found this:
https://www.mikesarcade.com/cgi-bin/store.pl?sku=NIN2JAMMA
Does anyone know what "built-in video color inverter" is?
JDFan
« Reply #3 on: January 12, 2015, 05:06:25 pm »
He also sells the video inverter and sound board separately and in it's manual ( https://www.mikesarcade.com/estore/datasheets/NinInvAmp.pdf ) it states :
This board is a great solution for using a new monitor with your Nintendo Boards. It’s
also can be used as a color corrector for Nintendo Sanyo and Sharp monitors, allowing
you to use them with standard game boards.
So looks like the video inverter board allows adjusting the RGB setting and allows using newer monitors in the system or nintendo monitors in other systems.
johnrt
« Reply #4 on: January 12, 2015, 05:09:09 pm »
Hmmm.. thanks! I'll see what I'm gonna do.
