Author Topic: What's the method for setting up monitor when using Linux?  (Read 1904 times)
DalSegno
  • Last login:June 23, 2024, 07:09:37 am
« on: January 10, 2015, 02:10:48 pm »
Hi guys,
New to this stuff. I have an Nvidia card (GTX 260 I think) and a Sony PVM 1341. I've got a few problems trying to run the Groovyarcade Linux Live CD:
-The setup and ArcadeMenu screens look interlaced, can I fix that?
-A lot of the free ROMs included won't sync on my monitor. Almost all the low resolution ones.
-A bunch of games that do work are shifted to the right. I see references to Arcade_OSD and setting porch settings everywhere but I have a suspicion this is all only in Windows.
  • Last login:Today at 01:59:25 am
Re: What's the method for setting up monitor when using Linux?
« Reply #1 on: January 11, 2015, 05:52:04 am »
Di DalSegno,
You need an interlaced mode to handle enough resolution for the text mode display, I'm afraid. So there's nothing to fix here. (Unless your PVM can handle 31 kHz, tell us if that's the case).
This is probably a low dotclock issue. Open mame.ini (ume.ini if you're using one of the latest distros). Search down for the "dotclock_min" value and replace "0" with "8.0".
Once you fix the problem above, tell us what monitor preset you are using and I'll show you how to fix this manually. Arcade OSD is Windows-only, yes.
DalSegno
« Reply #2 on: January 12, 2015, 12:17:27 pm »
Great, dotclock min = 8.0 worked so now all the games do indeed start up and sync.
As for setting the horizontal geometery I've just been using the generic 15khz setting.
