Author Topic: What is the strip called on the back of a Williams CP?  (Read 1176 times)
Fast351
  • Last login:November 22, 2020, 10:49:37 am
« on: January 03, 2015, 07:21:41 pm »
So on a Williams machine, the CP flips down.  At the back of the CP is a plastic strip that looks like a Y (see crappy ASCII drawing below) that sits between the glass and the CP and holds down the edge of the CPO.
Some 3/4" plastic channel and a heat gun would probably achieve the same effect, but does anyone know what this piece is called and if I can get one similar to the Williams piece on my upright?
Drawing
|  CP
Slippyblade
Re: What is the strip called on the back of a Williams CP?
« Reply #1 on: January 03, 2015, 09:11:14 pm »
Not sure what the actual name of that piece is called, but I just use rubber door sweeps on my machines.  $3 from Home Depot.
WindDrake
  • Last login:December 03, 2020, 09:49:05 pm
  • Electrical Engineer
« Reply #2 on: January 04, 2015, 01:09:15 am »
Arcadeshop calls it "Williams Control Panel Molding Trim". It's $4. Had to buy one when I converted my Stargate to a Multi-Williams setup. Mounted with 3M permanent mounting tape.
  • Last login:Yesterday at 06:17:10 pm
« Reply #3 on: January 04, 2015, 01:32:02 am »
I bought that same part from Arcadeshop for my Moon Patrol.
