Author Topic: Using Ultimarc PacLED64 to Illuminate Joysticks...  (Read 2145 times)
JV
  • Last login:May 17, 2022, 04:41:50 pm
« on: December 29, 2014, 03:27:35 pm »
Hi,
I am building my first Arcade Control panel.
I bought two player kit with illuminated joysticks & buttons.
I am going to wire the button leds to a PacLED64 and they seems straight forward.
However, I have a question regarding wiring the joysticks to the PacLED64.
The joysticks come with a 2 wire cable (red [15v] / black [GND]) to illuminate the joysticks and I'm not sure how to attach them to the PacLED64. Should I wire the joystick black[GND] wire to one of the "+" pins on the PacLED64 and the red[15v] wire to one of the 1 - 64 pins on the PacLED64 (I am assuming that the "+" pins are ground and the 1-64 pins are positive 15v's - is this correct?) - or should I wire it them other way round?
Any help would be much appreciated.
JV.
Re: Using Ultimarc PacLED64 to Illuminate Joysticks...
« Reply #1 on: December 29, 2014, 04:52:12 pm »
+ does not mean ground. Time for you too Google some basic electrical videos.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #2 on: December 30, 2014, 04:40:17 am »
I am not exactly sure which product you have, as the only illuminated joystick handles we have are RGB and they have 4 wires, none of which are black.
Andy
JV
« Reply #3 on: December 30, 2014, 06:26:31 am »
Hi Andy,
The joysticks I bought can be see here : http://www.arcadeworlduk.com/products/Illuminated-Arcade-Joystick.html
I was planning to illuminate them using a PacLED64 but now i'm not sure that the joysticks are suitable.
I'm a noob electrician so have been searching for some relevant tutorials as suggested.
If you know of any good tutorials that would be great.
JV.
AndyWarne
    • Ultimarc
« Reply #4 on: December 30, 2014, 09:38:16 am »
These are not our joysticks but they are single-color if they only have 2 wires so you could simply connect the wires to a 12 volt source such as a wall adaptor, or tap into a hard drive power connector.
Andy
JV
« Reply #5 on: December 30, 2014, 04:04:14 pm »
I will give tapping into one of the molex connectors a go so.
Thanks Andy.
Brian74
  • Yep... I built that!!
« Reply #6 on: December 30, 2014, 04:09:28 pm »
   :laugh2:
