Author Topic: Megatouch xl titanium monitor issue  (Read 3816 times)
didgey101
  • Last login:March 01, 2015, 04:56:25 pm
« on: December 27, 2014, 06:02:22 am »
Hi all, I've got a bartop megatouch xl titanium at home and I've just spent weeks building a windows xp unit using the inde sim emulator and simpletouch fe which is all working perfectly with loads of swp games but I'm having a problem getting it to display on the megatouch monitor? The touchscreen driver is all working as it should. When the pc boots up it displays the post screen and the windows logo perfectly but when it gets to the desktop screen or when the front end boots up the screen goes all scrambled and fuzzy? I changed the display settings to 75 hertz which improved it a little bit but still does the same thing. Any ideas on what I can do to resolve please? Many thanks... Tim
M.Lanza
  • Last login:October 09, 2015, 09:51:03 am
Re: Megatouch xl titanium monitor issue
« Reply #1 on: December 31, 2014, 12:34:41 pm »
Do you have it set to the correct resolution?
It should be 640X480.
Trample the weak, hurdle the dead
lilshawn
  • Moderator
  • Last login:October 27, 2025, 06:16:21 pm
« Reply #2 on: December 31, 2014, 02:13:18 pm »
the refresh rate should probably be set to 60hz.
ed12
« Reply #3 on: December 31, 2014, 03:11:37 pm »
or try 15khz sw.
ed
