Author Topic: Resize screen ?  (Read 1116 times)
maximebeauvais
  • Last login:January 28, 2019, 10:55:35 am
Resize screen ?
« on: December 24, 2014, 09:36:00 am »
I have bought a jamma board that have horizontal game cart and vertical game cart. I just have to switch the cart to play horizontal or vertical game.
However, i have to physically turn the screen of my monitor if I want to play the games.
Is there a module or board or something what could resize the screen to play vertical game using the horizontal position of the monitor.
I want to built a bartop with a horizontal monitor positon. however, if i want to play vertical game, I will have to turn my monitor (which I don't want to do it) !!!
thanks
maximebeauvais
Re: Resize screen ?
« Reply #1 on: December 26, 2014, 09:14:55 pm »
someone ?
ahofle
    • Arcade Ambience Project
Re: Resize screen ?
« Reply #2 on: December 27, 2014, 12:53:02 am »
Is this running on a standard arcade monitor?  Vertical games are supposed to have the monitor rotated 90 degrees and most likely won't run horizontally on a CGA monitor due to the non-standard resolution that would be required.
maximebeauvais
Re: Resize screen ?
« Reply #3 on: December 27, 2014, 11:26:00 am »
I will be using a PC monitor. Does it make a difference
  • Last login:Yesterday at 08:33:44 pm
Re: Resize screen ?
« Reply #4 on: December 28, 2014, 02:43:12 am »
Answer? Probably not.
maximebeauvais
Re: Resize screen ?
« Reply #5 on: December 29, 2014, 01:21:16 pm »
ok, thanks for you help. I will probably just use the vertical game anyway since most of my favorite game are vertical.
