Author Topic: can someone with win7 help me get super resolutions working?  (Read 4563 times)
Psicosis
  • Last login:December 24, 2014, 11:10:12 pm
« on: December 15, 2014, 05:49:05 pm »
I have been trying and trying to get this working for the past 4 days :dizzy:. I decided to upgrade my cabinet to windows 7 64 from windows xp64 so I formatted the computer and started from scratch. I am using a 15khz arcade crt in my cabinet with a radeon 4870. I got the crt emu drivers installed and working. I got vmmaker working and installing video modes and I am able to get groovymame working and loading games, if I set up vmmaker the old way with a bunch of standard resolutions. They show up normally in arcade osd but it appears the interlaced ones including my 640x480i only show when I select lock unsupported modes to no in arcade osd.  Here is where the problems start, when I run vmmaker to set up super resolutions it installs them but they are only visible in arcade osd if I select lock unsupported modes to no in arcade osd. Is that correct? Can someone give me exact directions to setting up groovymame to run super resolutions so I am not missing anything. Can someone post their mame.ini that is using groovymame with super resolutions so I can see exactly how everything should be set.
  • Last login:Yesterday at 02:43:50 am
« Last Edit: December 15, 2014, 05:59:06 pm by Calamity »
Psicosis
Re: can someone with win7 help me get super resolutions working?
« Reply #2 on: December 15, 2014, 06:35:42 pm »
thanks for the quick response Calamity I have read these posts and believe me I have been reading and trying things for days, I am able to select 640x480i 15khz by right clicking on desktop/ screen resolution/advanced settings/adapter/list all modes and my cabinet boots fine everytime in 640x480 15khz.  I also did the lock_unsupported_modes 0 in mame.ini thinking that it would let mame use the 2560 super resolutions that are only visible in arcade osd if I select lock unsupported modes to no in arcade osd. but It still didnt work.  Am I putting resolution 2560x0 in mame.ini in the correct place? Where exactly should this be in mame.ini? thanks
Psicosis
« Reply #3 on: December 15, 2014, 06:49:56 pm »
when I first found capitaineflam25 post I thought I had found the answer to my problem because he was having what appears to be some of the same problems and error screen.  But when I use video ddraw in mame.ini groovymame does finally load a game but it is not correct, when I hit tab and look at the game info it doesn't show a switchres resolution below the games resolution it just shows the games resolution.
« Last Edit: December 15, 2014, 06:56:28 pm by Psicosis »
« Reply #4 on: December 16, 2014, 04:07:10 am »
Hi Psicosis,
You must be doing something wrong in your .ini. Post your mame.ini and create a log of a sample game: http://forum.arcadecontrols.com/index.php/topic,135823.0.html
Psicosis
« Reply #5 on: December 16, 2014, 08:35:53 am »
Where does 2560x0 go at in mame.ini? I wont be able to post anything till later today when im home
« Reply #6 on: December 16, 2014, 09:21:25 am »
Look for 'resolution auto' in mame.ini, change it for 'resolution 2560x0'. I'm assuming you created mame.ini using the groovymame executable.
Psicosis
« Reply #7 on: December 16, 2014, 07:48:11 pm »
ok Calamity I got it working correctly and switchres is showing the 2560 resolution in game info screen now, in all my hours of switching things on and off in mame.ini I ended up putting the 2560x0 under screen instead of resolution the last time I added it, when I originally had it in the correct spot.  :banghead: So my question now is why do people like me and capitaineflam25 have to run it with "lock_unsupported_modes 0" and "video ddraw" in mame.ini and what I am most concerned about is What are the drawbacks, concerns and problems to having to run in ddraw mode instead of d3d? slower? more input lag? etc. anything I should know?
adder
« Reply #8 on: December 16, 2014, 07:59:14 pm »
there is some info about ddraw vs. direct3d in this link below if you wanted to check it out:
http://forum.arcadecontrols.com/index.php?topic=139130.0
Psicosis
« Reply #9 on: December 16, 2014, 08:23:51 pm »
thanks jadder, it sounds like ddraw is perfectly fine until i get to this sentence,("But ddraw is terribly flawed with W7, its set-display-mode api just can't handle interlaced/progressive mode switching and bilinear filtering is only supported with flipping surfaces. So some dirty workarounds had to be implemented in GM to make ddraw an usable option".)  I am not sure what it exactly means tho.
« Reply #10 on: December 22, 2014, 04:50:54 pm »
It means that despite of those problems, a lot of effort was put into making DDraw usable in GroovyMAME without any issues.
