Author Topic: Sketchup Help Needed  (Read 1777 times)
tkropp17
  • Last login:December 02, 2017, 01:52:18 pm
  • Can't figure out how to change my username
« on: December 14, 2014, 11:10:34 pm »
I'm venturing into making a cab with a 50" LED screen mounted vertically and need help making an outline. I've been working in photoshop to make the outline, but i'm running into some roadblocks and need help with making it work.
TJ
« Last Edit: December 15, 2014, 03:29:31 pm by schlsux »
AzureKnight
Re: Anyone Good w/ Arcade Outlines?
« Reply #1 on: December 15, 2014, 10:14:15 am »
What kind of roadblocks?  Help us help you?  :)
tkropp17
« Reply #2 on: December 15, 2014, 11:03:44 am »
Essentially, I was making the attached in photoshop, then I turn it into a PDF and take it to FedEx to print an outline. I've done this with a few other things. However, I'm trying to fit in a 50" TV this time and make it look good lol. The TV is 44" tall when vertical, the top 8.5" are black space, the next 24" is playable area, followed by 11.5" of black space.
« Reply #3 on: December 15, 2014, 11:24:17 am »
Your best bet is to create something using SketchUp.  Here's a great example of how another member planned out his cab with that tool:  http://forum.arcadecontrols.com/index.php/topic,141562.0.html
It will save you a lot of frustration in the long run and you can "virtually" see if everything fits before building it.
D
tkropp17
« Reply #4 on: December 15, 2014, 12:36:25 pm »
I've tried sketchup and I guess I have to read some tutorials on it or something. I didn't get how to use it. Thanks for the advice.
« Reply #5 on: December 15, 2014, 02:23:45 pm »
Some users here may be able to help.  They are pretty proficient at it.
You may want to modify your first post's Subject to read:  "Sketchup Help Needed" or something similar.
D
