Author Topic: Ultimate Scart Adapter UMSA on NTSC CRT TV through COMPONENT YUV with soft15khz  (Read 2249 times)
mrfardoche
  • Last login:April 28, 2015, 09:24:58 pm
Hello all,
I am baffled. spent the day trying to make things work, i really don't know what is wrong...
Okay so here it my setup:
HP Dc7900 computer  - VGA wire - soft15khz dongle - UMSA with a 5Volt powersupply at 1Amp- Scart to YUV converter - NTSC TV
I am getting colors, and they look nice. The picture on the other hand is VERY distorted. It's rolling, up, down, sideways, the image is all warped... let me show you a video on youtube of it:
I really don't know what else to do.. i actually have 2 UMSA's and 2 Edid dongles. tested both and i am always getting the same result on the TV.
The emulator i am running it on right now is groovyume.
It's becoming a pain to setup up, always connecting, disconnecting the CRT to the VGA monitor and rebooting.
Anyone has a solution, or a suggestion? i would greatly appreciate it.
thanks in advance
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
thats a hell of chain . im suprised it outputs anything at all . the umsa was designed to simplify connecting a pc to scart rgb . why dont u take a well working known gc like one of the radeon 4xxx modells + crt emudriver and connect it directly to a rgb-yuv converter via15 pin sub d cable ? i guess u dont have a scart rgb tv or an old pc-atari-amiga multisync crt at hand . would help a lot to narrow down ur probs .
ur problem can be related to lots of things . maybe issues with the resolution , refrehrate or sync . have u tried changing the sync jumper on the umsa pcb ?
