Author Topic: WG colors off, but just a bit  (Read 1703 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
« on: December 11, 2014, 11:08:49 am »
When playing the game, there is no color issues.
When running through the color tests, when displaying a full red screen, there is a noticeable "blob" that has a green tint to it.
Obviously turning up the red will not help in this case.
Will a desgauss fix this?
grantspain
Re: WG colors off, but just a bit
« Reply #1 on: December 12, 2014, 03:27:24 am »
do you have a photo?
if you rotate the cab powered on and the area changes then yes degauss may work,if not then there may be some damage to the shadow mask
Sarver Systems
« Reply #2 on: December 12, 2014, 01:54:34 pm »
I'll grab a pic, but I'm not sure it'll be noticeable enough to come through in the pic.
mgb
  • North East, US
« Reply #3 on: December 13, 2014, 11:46:59 am »
Sounds like you're explaining a degauss issue though that should show during game play too.
But it's always easy and quick enough to run a degauss.
