Author Topic: Monitors Color RGB transistors and resistors  (Read 1580 times)
vanwatson
  • Last login:January 02, 2015, 09:21:39 pm
« on: December 06, 2014, 02:47:49 pm »
Does all Arcade monitors have these RGB resistors and transistors?
The Red channel has a resistor and a transistor that gets connected to the monitor display
The Green channel has a resistor and a transistor that gets connected to the monitor display
The Blue channel has a resistor and a transistor that gets connected to the monitor display
They call this circuit a discrete ADC convert , but what is the resistor and transistor called in the arcade tech world?
vanwatson
Re: Monitors Color RGB transistors and resistors
« Reply #1 on: December 06, 2014, 04:19:36 pm »
I'm not sure if these transistors are called the video output buffers
But I see a lot of times are trim pots that are RED cutoff, Blue cutoff, Green Cutoff
Are theses adjusting the Colors amplitudes or cutting off what?
ed12
« Reply #2 on: December 06, 2014, 04:35:30 pm »
the to220's are video output's
the "cut off controls" are self explantory >cut-off<
ie the gun r/g/b which ever u want to "cut-off"
it is a sub set of gain control's for the tube gun in question or gun's which ever
ed
