Author Topic: groovymame configuration  (Read 2506 times)
limner
  • Last login:June 08, 2015, 06:59:42 pm
« on: November 15, 2014, 06:19:45 pm »
Good evening
where can i find a doc to understand how to configure groovymame?
At this moment i'm trying to use it on a pc with an lcd but after i will understand i will use it with a D9400 wells gardner.
At this moment i installed it, but when i try to launch it i've an error about switchres not able to find the right spec/mode for my monitor: how can i fix it?
adder
Re: groovymame configuration
« Reply #1 on: November 15, 2014, 06:24:18 pm »
hi, you can read up on the documentation here:
http://geedorah.com/eiusdemmodi/forum/viewforum.php?id=1
there is a step-by-step guide here:
http://forum.arcadeotaku.com/viewtopic.php?f=10&t=24216
  • Last login:Yesterday at 10:59:40 am
« Reply #2 on: November 16, 2014, 05:04:22 am »
You need to create mame.ini, and set:
monitor lcd
aspect 16:9 (or whatever aspect your monitor has)
GM's default config is "monitor generic_15" which obviously expects a 15 kHz monitor, thus the error message.
