Author Topic: Single button power on/off for Raspberry Pi Bartop  (Read 8623 times)
Turambar
  • And I don't watch Fox news or use Happ joysticks.
  • Last login:October 03, 2021, 11:10:13 pm
  • Owner of Wayback's Arcade
    • Wayback's Arcade
« on: November 13, 2014, 07:12:18 pm »
I'm building a pi based bartop, and I want to have an arcade button power on everything (marquee, monitor, speakers, and pi). I accomplish this on my PC driven arcade cab with a smart strip with the PC in the control socket.
I'm using a mausberry circuit to turn the pi on and off (http://bit.ly/1B9lMpW). Has anyone used one with a smart strip?  Are there any other one button solutions for cutting everything on?
**Pardon me if this has been asked before.  I couldn't find it via search.**
« Last Edit: November 13, 2014, 08:18:20 pm by Turambar »
ark_ader
  • I glow in the dark.
Re: Single button power on/off for Raspberry Pi Bartop
« Reply #1 on: November 14, 2014, 06:09:27 am »
Thanks for sharing that link.  :cheers:
nitrogen_widget
« Reply #2 on: November 14, 2014, 07:12:33 am »
I was going to use either the standard power adaptor and a power strip or a PC power supply to power everything and just run the shutdown command via script from the front end.
The front end is advmenu and I was going to setup the shutdown/reboot scripts as a second emulator.
keilmillerjr
  • Web Developer.
« Reply #3 on: November 14, 2014, 07:59:41 am »
I've been thinking about using a raspberry pi for a retro console unit and found this for turning it on and off. It's sold as a diy solder kit, so I assume the supplies buttons can be replaced by wires leading to any momentary switch.
https://www.pi-supply.com/product/pi-supply-raspberry-pi-power-switch/
And for your project, maybe you can use one of these Eco-strips? I used one for my mame pc. My motherboard constantly feeds power through usb and is not changeable through bios, so I just used a usb to molex adaptor and connected it to my power supply that way.
http://www.m.ecostrip.com
You could possibly use these two units together with the raspberry pi to have everything turn on and off with a button press, albeit it might be two seperate buttons for the process.
