Author Topic: Where to buy pots?  (Read 1560 times)
Sarver Systems
  • Last login:October 07, 2020, 12:46:05 am
Where to buy pots?
« on: November 06, 2014, 08:13:41 am »
I've been doing enough monitors lately that I want to start stocking pots.
Where is the best place to order about 5-10 of each size?
I'm talking about the pots that go on the remote adjustment boards (contrast, v-hold, v-size, etc...), on the neck boards (R-drv, g-drv, etc...) and on the main boards (if there is no remote board).
I ordered a replacement kit off of amazon, but the pots are a little too small to fit the through-holes. I can make them work, but I'd like to have exact replacements if possible.
Re: Where to buy pots?
« Reply #1 on: November 06, 2014, 08:52:59 am »
Colorado, Oregon, Washington, or Alaska. Take your pick. :laugh2:
But seriously, try Bob Roberts.
copados33
  • Last login:March 07, 2025, 08:23:35 pm
« Reply #2 on: November 06, 2014, 09:00:43 am »
Been on the same boat lately, never seen them for sale, I have even asked to some tech guys that work on this stuff and they didn't know where to get them other than from scraps from other monitors.
spoot
  • Destroyer of electronics
« Reply #3 on: November 06, 2014, 11:12:50 am »
Try:
mouser
digikey
Ken Layton
  • Guru
  • Technician
« Reply #4 on: November 06, 2014, 11:51:16 am »
Bob Roberts carries the vast majority of trimpots used on arcade game monitors as well as on power supply boards, sound boards, game boards, etc.
http://homearcade.org/BBBB/pots.html
Specific "kits" for certain monitors and sound boards are here, just scroll down to the pot section:
http://homearcade.org/BBBB/parts.html#pots
« Reply #5 on: November 06, 2014, 12:08:12 pm »
Newegg sells pots for real cheap  >:D
  • Last login:February 12, 2026, 03:35:47 am
« Reply #6 on: November 06, 2014, 12:18:54 pm »
I'd recommend this place, but ironically, they don't sell pots: http://www.potterybarn.com/
Sarver Systems
« Reply #7 on: November 06, 2014, 12:21:46 pm »
The Colorado joke...I expected that.
The pots and pan joke...niiiiice....didn't expect that one.
I know Bob Roberts has em, but I wanted to order like 10 of each, at a much cheaper rate.
I also found a few on mouser, but not exact matches. I'll have to dig a little deeper I think on there.
Thanks guys!
  • Last login:Yesterday at 06:18:12 pm
« Reply #8 on: November 06, 2014, 02:12:13 pm »
Other vendors to consider are Allied Electronics and Arrow.
Sarver Systems
« Reply #9 on: November 06, 2014, 02:40:26 pm »
I think the hardest part is just knowing which ones to buy, based off of the physical dimensions.
I'll have to look at Bob's site since he has a pretty good layout showing all the domensions.
Ken Layton
  • Guru
  • Technician
« Reply #10 on: November 07, 2014, 12:01:56 am »
It's a lot easier to find pots in Mouser's hard copy catalog. Then you plug the part numbers into the search box on Mouser's website.
Here are some considerations you need to keep in mind when looking for trim pots:
1. Knob size. Many are 9mm diameter knobs. Alot no longer have a finger shaft and require you to use a small flat blade screwdriver to adjust them. Some neckboard color adjustment pots are 6mm diameter.
2. Mount style: horizontal or vertical. Does the pot lay flat against the board or does it stand up?
3. Value. The resistance value of the pot.
4. Lead spacing/footprint.
Sarver Systems
« Reply #11 on: November 07, 2014, 09:11:15 am »
Not a prbolem for me either way, but I agree, the knob would be nicer than needing a tool to adjust with (especially for the client)
I agree. I would order an equal amount of both styles.
I would order an equal amount of each known value, or look at which ones are more popular and order more of those.
The most important part, and this is where I am getting stuck at.
