Author Topic: Need some help Mame on a HD lcd  (Read 2008 times)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« on: November 02, 2014, 10:11:00 pm »
Hey guys
im trying my hand on using a lcd inside a cab this time around, im using a Panasonic viera (26") (hdmi) mame version 106, what would be the optimal resolution/options that I could use to improve the picture, everything is very much pixilated. Suggestions please , mame version want not. thanks
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
MAME TIME
Re: Need some help Mame on a HD lcd
« Reply #1 on: November 03, 2014, 12:06:30 am »
Nevermind I got the "effect" I was looking for, I turned the sharpness all the way down on the tv, looks better!!
Geometry Arcade
Neo Geo 360
MK2 standup
EMDB
  • Project RetroCade
« Reply #2 on: November 03, 2014, 06:34:44 am »
I think you should only adapt the in game picture quality (using HLSL or a hardware scan generator) and let your frontend benefit from the HD quality of your screen.
MAME TIME
« Reply #3 on: November 03, 2014, 03:36:01 pm »
Question is, is HLSL compatible with an older version of mame (106)?? i'd defiantly like to give it a try
Geometry Arcade
Neo Geo 360
MK2 standup
nitrogen_widget
« Reply #4 on: November 06, 2014, 07:18:27 pm »
if you are using .106 try out advmame.
I use that on older hardware.
it does scanlines & has some nice scaling filters.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #5 on: November 12, 2014, 11:08:05 am »
HLSL looks fantastic... after using it I wish I could get that exact effect on every emulator I use.
I used this guide: http://www.videogameperfection.com/2014/07/27/hlsl-for-everyone/ and then I set the pincushion to 0 as I'm not a fan of that effect.
Is there a reason you're using .106 instead of the newer builds?
lamprey
« Reply #6 on: November 12, 2014, 12:45:50 pm »
Not to derail the thread but have you seen the stuff Jezz did? The main advantage of his Post.fx mod is that you don't need to change the shadow_mask_?_count for each game to keep the right ratio; It figures it out of you. Plus some other goodies which you may or may not care about:
http://www.aep-emu.de/PNphpBB2-file-viewtopic-t-18991.html
(it's in German, so use your favorite translator if you don't speak/read German)
Also, there has been some buzz about Timothy Lottes' shader. It uses GLSL (SDL/OpenGL), so you have to use an SDL build of mame. But, it might be of interest to you. Although, not a real CRT emulation, it looks pretty darn good. Here is a thread about it:
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=330562&page=4&view=collapsed&sb=5&o=&fpart=1&vc=1&new=1411805500
Cheers!
twistedsymphony
    • solid-orange.com
« Reply #7 on: November 12, 2014, 01:15:28 pm »
Cheers!
That's pretty neat, I'll check it out, though at this point I'm mostly looking for what I can do to make stuff outside of MAME and MESS not look like crap.
