Author Topic: IPac and Raspberry Pi question  (Read 12105 times)
mvolke1
  • Last login:August 27, 2020, 09:48:24 am
    • My Pi-Powered Galaga-Thmed Bartop
« on: October 27, 2014, 11:24:13 pm »
I'm planning on using an iAc with my Pi. I'm thinking it'll be plug and play since it's set to MaME default controls. Has anyone ever done this? If so did you have to do any programming? Thanks
I'm with stupid.
nitrogen_widget
Re: IPac and Raspberry Pi question
« Reply #1 on: October 28, 2014, 07:43:43 am »
I would try the piplay and retro pi forums along with the raspberrypi forum itself.
spoot
  • Destroyer of electronics
« Reply #2 on: October 28, 2014, 11:25:31 am »
Haven't tried it myself, but since the ipac is more or less a usb keyboard in this case I'd be surprised if it didn't work.
mvolke1
« Reply #3 on: October 28, 2014, 12:45:39 pm »
According to this post, it works fine: http://www.raspberrypi.org/guest-blog-6-mame-cabinet-by-darren-j/
I have an iPac 4, which I am reusing from a previous project I scrapped.
I'm with stupid.
Locke141
  • Never grow up.
« Reply #4 on: October 28, 2014, 01:36:40 pm »
You could get a cheep encoder like two zero delay ($10.34 each) and sell the I-pac here.
http://www.ebay.com/itm/NO-Delay-USB-Encoder-PC-to-Joystick-Arcade-MAME-Multicade-2pin-Happ-Push-Button-/191065889930?pt=LH_DefaultDomain_0&hash=item2c7c6a1c8a
Hell, you could use the GPIO pins on the I R-pie. Go ask on the PiPlay forums on how to do this.
nitrogen_widget
« Reply #5 on: October 28, 2014, 03:52:30 pm »
there was an issue with emulationstation 2 and the GPIO app.
Something to do with sdl2.
there is also a fix I believe.
I haven't gotten to this point yet (just got my gpio breakout adapter & breadboard) but i'm also using advanced menu so I shouldn't have these problems.
mvolke1
« Reply #6 on: October 29, 2014, 12:45:02 am »
Testing the ipac and it wwill dis great with MAME. However it doesn't sent work for consoles since the iPac uses the default buttons for MAME. Shouldn't be too bad to change them.
I'm with stupid.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
« Reply #7 on: October 29, 2014, 03:48:32 pm »
Interesting. Have you actually bought one of those encoders? They look remarkably cheap. I presume they're not programmable but at that price who cares.
  • Last login:Today at 12:29:54 pm
« Reply #8 on: October 29, 2014, 03:51:58 pm »
Based on my experience, at that pricepoint I'd rather buy a MinimusAVR from xconsoles.com and load the KADE firmware on it. I used one of those from eBay a few years ago to build a bartop for my nephews, but I just got it back from them because the controls are unreliable. Gonna switch it out with a Minimus I got last week - haven't had ANY issues with those.
mvolke1
« Reply #9 on: October 29, 2014, 04:35:24 pm »
For my money, the ipac couldn't be easier. I think it's like $35.
I'm with stupid.
« Reply #10 on: October 29, 2014, 05:10:02 pm »
Completely agree - but if you want to spend $10-$15, a Minimus is the way to go.
sharpfork
    • KADE
« Reply #11 on: November 02, 2014, 12:37:37 am »
I'm setting up my first raspi emulation brain and no way do I want to use any processor cycles checking gpio pins.  I hear the zero delay's are fine in most cases.  Minimus + KADE software is a super cheap way to go too.  You can program it as keyboard or HID joystick.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #12 on: November 02, 2014, 06:48:53 am »
We have many customers using I-PACs with the Pi and no reported issues.
Locke141
  • Never grow up.
« Reply #13 on: November 02, 2014, 07:05:35 am »
 I-pac 4 run for $65 before shipping. Your bar top build is nice enough to justify the price of the I-pac. If I went that rout I would have gotten one of the cheeper models.
« Last Edit: November 02, 2014, 07:10:46 am by Locke141 »
Locke141
  • Never grow up.
« Reply #14 on: November 02, 2014, 07:11:25 am »
I have one but from a different vender. It seems to work fine on a little test rig I built. Plans are in the works to use it in a stick build.
If I didn't already have one I'd be taking yotsuya advice as he definitely knows better then I.
True,
 That never crossed my mind.
« Last Edit: November 02, 2014, 12:07:10 pm by Locke141 »
