Author Topic: FOUND: Over Under Coin Coin door or Coin Controls door frame (Houston)  (Read 936 times)
Mitkraft
  • Last login:October 30, 2015, 03:04:41 pm
UPDATE: I found one.  Thanks for the help everyone!
So I finally got started on my 2 mame cab builds and I've made my first major mistake.  While trying to clean up the coin door I completely destroyed the frame.  The original is a Coin Controls over under from a Dynamo HS-5 cabinet.  I'm guessing I'll need a new frame (if they match) or an entire unit.  The unit was complete except for the removable coin bin so I still have all the other parts.
As for what I have to trade since I'm just starting I don't have much in the way of arcade parts.  I do have a tron control panel that I planned on selling (needed the controls but not the panel) but its probably worth more than a coin door.  I do have a TON of computer parts since I've been in IT (both as a hobby and profession) for nearly 20 years. Come to think of it I have a lot of misc. electronics laying around so if you have one and might want to trade drop me a line and let me know what you might need.
Mitkraft
« Last Edit: October 24, 2014, 02:16:03 pm by Mitkraft »
Re: WTB/WTT Over Under Coin Coin door or Coin Controls door frame (Houston)
« Reply #1 on: October 22, 2014, 02:40:41 pm »
post a picture of what you need.
Mitkraft
« Reply #2 on: October 22, 2014, 05:22:49 pm »
I should have included that in the first place shouldn't I?   :banghead:  I forgot I had a picture from before I destroyed it.  This is of a Dynmo HS-5 cab.  What I need is just the frame part that mounts to the cabinet.  The doors and coin-mechs that attach to it are undamaged.  If I can't find a frame to match then I'll have to replace it with an entire coin door that will fit in that hole.  I really don't want to have to modify a door or the front panel to make a different one fit.
https://www.dropbox.com/s/s71r7siknijni2k/2014-10-18%2016.36.30.jpg?dl=0
  • Last login:Yesterday at 12:03:57 am
« Reply #3 on: October 22, 2014, 09:09:14 pm »
Go to arcadecenter.com, join the mailing list, and post on there.  They're having a show in a couple of weeks and somebody or another will hook you up.
