Author Topic: MiniPac Wiring  (Read 929 times)
newoski
  • Last login:February 26, 2021, 07:44:50 am
MiniPac Wiring
« on: October 19, 2014, 10:21:44 pm »
Hi Guys,
Quick question about MiniPac wiring.  I had planned to use a friend's WinIPAC layout, but now I'm adding 2 extra buttons for Pinball Flippers.
I've created my own layout in WinIPAC, but I'm confused about the SW assignments.
So long as I map the desired keyboard key to the desired button/SW, does it matter which SW I assign to each button?
Put another way, as an example, could I randomly assign SW(s) for player 1 and 2 without creating problems... so long as I keep track of my SW to Key mappings?
Thanks so much,
Owen
« Last Edit: October 19, 2014, 10:23:26 pm by newoski »
  • Last login:Today at 06:04:22 pm
Re: MiniPac Wiring
« Reply #1 on: October 20, 2014, 01:36:46 am »
You can assign any keystroke to any input that you like.
There is some overlap between the MAME defaults and the less flexible Visual Pinball/Future Pinball defaults.
You can wire more than one switch to a single input.
« Last Edit: October 20, 2014, 01:38:56 am by PL1 »
