Author Topic: Running MAME on android.  (Read 7797 times)
thehammer12
  • Last login:October 24, 2021, 01:46:34 pm
  • Arcade Breaking Specialist
« on: October 17, 2014, 12:41:04 pm »
Has anyone here set up MAME on android? Is it possible to do this without using the app's MAME4DROID or MAME4ALL?
I tried running it on my phone last night, and most of the rom's I came across weren't working for those apps, so I wanted to try this on my tablet and my mini pc. I also want to use regular push buttons and joysticks.....not controllers which those apps use and or are compatible with.  Any suggestions?
Generic Eric
Re: Running MAME on android.
« Reply #1 on: October 17, 2014, 12:52:10 pm »
I had a similar problem getting it to run
Bluetooth gamepad or keyboard.
thehammer12
« Reply #2 on: October 17, 2014, 01:11:30 pm »
Did you try running MAME (non app version) on it?
Generic Eric
« Reply #3 on: October 17, 2014, 01:21:34 pm »
No just mame4droid
Yenome
  • Last login:November 14, 2025, 04:36:28 am
  • Punch a fish. Make a wish
« Reply #4 on: October 17, 2014, 01:26:44 pm »
I had to use set .38 with the droid apps not sure on a version that is not an app that works for droid
nitrogen_widget
« Reply #5 on: October 17, 2014, 01:33:39 pm »
mame4droid is .37b rom set.
mame4droid reloaded is .139 romset.
Retroarch android is .72 or .78 romsets.
I have dual core android stick (gamestick with custom rom) and it works just fine with all versions of mame with the right romset.
there isn't a very good front end for android yet & the mame4droid's don't support shortcut launching that I know of so you are stuck with their text based front end.
retroarch does work with the only front end I found for emulators called gamesome but navigating with gamepad sometimes doesn't work.
Yenome
« Reply #6 on: October 17, 2014, 01:43:25 pm »
forgive me ignorance at the moment but doesnt the rasberry pi run android. if so same steps should work with a lil tweaking on mini pc.
thehammer12
« Reply #7 on: October 17, 2014, 02:15:36 pm »
Hmmm, Ill give them both a try but was curious if anyone else tried this before me. Thanks though.
I haven't tried retroarch or gamesome front end, when you say it sometimes doesn't work....what did you do restart the system to get it to work? was it more of a lag? Just curious.
Interesting, I dont have a RP right now so I cant test it out. Maybe for the next project I can try it out, I will take a look at the process and see how others are tweaking it.
Thanks.
Yenome
« Reply #8 on: October 17, 2014, 03:47:36 pm »
sorry rasberry pi uses linux. didnt do too much checking but i didnt see android listed.
thehammer12
« Reply #9 on: October 18, 2014, 12:47:50 am »
No worries bro, im gonna try and get MAME running on my mini pc and throw it in a full cab. I would like to get it with a decent front end but from what im hearing....probably not.
nitrogen_widget
« Reply #10 on: October 21, 2014, 01:15:54 pm »
Thanks.
All the mame's work with a touch screen or mouse beautifully.
so does gamesome.
The problem is with the gamepad.
Gamesome sometimes doesn't recognize the joysticks being pressed on the gamepad so you cant pick a game.
Now, I can use a mini trackball to move the cursor around & select games to launch that way just fine though.
I keep hoping that Nostalgia frontend hits google play so we can use that on android.
It works well on ouya.
« Last Edit: October 21, 2014, 01:17:52 pm by nitrogen_widget »
thehammer12
« Reply #11 on: October 21, 2014, 03:35:47 pm »
so does gamesome.
Hmmm I tried using a wireless mouse and it didnt work, let me try it again and see what happens.
taylormadelv
  • Last login:February 18, 2019, 05:46:59 pm
« Reply #12 on: November 08, 2014, 05:07:35 pm »
I could not get a mouse to work on Mame4droid either. I cannot find a Bosconian Rom set that will work in Mame4droid.
thehammer12
« Reply #13 on: January 20, 2015, 02:07:36 pm »
Update: I have had some progress with my Android pc using a generic usb controller, joystick got picked up. Now I have to wire up the push buttons and cross my fingers, still no front end though.
