Author Topic: Sprayer vs Roller  (Read 1279 times)
Richardgregory
  • Last login:November 17, 2021, 01:15:10 pm
Sprayer vs Roller
« on: October 05, 2014, 12:00:48 pm »
I thought I would starta separate thread on the topic of painting. Some might have already read my other thread about helping a friend paint his cab. Well, he is expecting a pristine finish.  I'm not bad at painting with a roller but looking at my paint job of my own work, I have some roller/lap marks ..visible at an angle against a bright light.  I told and showed my friend my job and i think he is expecting a perfect smooth no mark finish :p So here's a question:  especially using dark paint color such as  black satin and a roller, is it expected to see some roller/lap marks?   Maybe I terribly suck at painting  :dunno
I mention to use of a sprayer for a more or near perfect finish but I don't think a sprayer is any easier right?
Re: Sprayer vs Roller
« Reply #1 on: October 05, 2014, 12:13:36 pm »
If he is expecting it to look like laminate, he's going to have to use laminate.
That said, I bought one of these to get some painting done quickly around the house:
If that's what you're thinking of using, you should know this:
It spits paint more than sprays it (doesn't matter how it's thinned).  Everything I used it on ended up with a textured surface.
I was happy with it for the purposes I was using it for, but I would not spray an arcade cabinet with it.
The more expensive setups that use bigger pumps or an air tank might do a better job.
« Last Edit: October 05, 2014, 12:15:16 pm by BadMouth »
« Reply #2 on: October 05, 2014, 01:36:26 pm »
Sprayed black enamel over sprayed primer has always been best for me.
myntik1
  • Last login:April 26, 2021, 12:03:28 pm
  • I'm part Jerry Lee and part Jerry Lee Lewis
« Reply #3 on: October 08, 2014, 10:30:41 pm »
my next cab project in a few weeks will force me to get the preval system or try the thinned out roller trick.
http://www.rickwrench.com/index79master.htm?http://www.rickwrench.com/50dollarpaint.html
full-time sucker for part-time pay
