Author Topic: Single audio power amp pinout  (Read 4486 times)
mahkeymike
  • Last login:Yesterday at 03:58:50 pm
« on: September 24, 2014, 09:27:14 am »
One of the ceramic caps blew on the classic force speaker amp board. Trying to fix it but i dont have any specs on what uF it is. Anyone know?
ed12
Re: Single audio power amp pinout
« Reply #1 on: September 24, 2014, 11:11:22 am »
i will grab an amp today and let u know
ed
mahkeymike
« Reply #2 on: September 24, 2014, 11:41:03 am »
cool thanks
  • Last login:Yesterday at 03:27:41 pm
« Reply #3 on: September 24, 2014, 01:51:25 pm »
i removed it an measured it (since i happen have one right here.)
it's 0.1uf
looks like it's just doing some bypass filtering (one side is connected to ground). you may not even need it. remove it and see if it works. most common failure of these caps is shorting out.
« Last Edit: September 24, 2014, 01:56:50 pm by lilshawn »
mahkeymike
« Reply #4 on: September 24, 2014, 01:57:01 pm »
i removed it an measured it (since i have one right here. it's 0.1uf
Thanks shawn. I think i have some 0.1uf caps in one of my parts bins. One of the traces burned up aswell so i will have to repair the trace anyway so might aswell replace the cap even if its not needed. :cheers:
ed12
« Reply #5 on: September 24, 2014, 02:16:57 pm »
ya c5 is a .1 bypass
noteing to worrie about
looking at the board now
thk's for the help shawn
ed
ed12
« Reply #6 on: September 24, 2014, 10:10:14 pm »
did the 12v rail go south on that thing?
as there is a 16v filter cap in there also.
ed
mahkeymike
« Reply #7 on: September 25, 2014, 08:56:56 am »
ed
I dont know. I got the cabinet with the audio board, and classic force IO board still in it. It was actually a bonus because i was buying a bunch of empty XL/Maxx cabinets for like $20 each.
Anyway, I fixed it last night. I had some 1206 smd caps i could have used but it was easier to use a through hole type ceramic disc cap since the legs were used as a jumper for the traces that were burned up.
