Author Topic: x-Arcade coin door  (Read 1868 times)
fr_303
  • Last login:July 25, 2016, 01:23:36 am
  • 1st cab done!!!
x-Arcade coin door
« on: September 22, 2014, 10:00:50 am »
HI I have an X-arcade coin door I want to change the coin mech in it, can I use any mech or does it have to be a specific one.
I have found a mech on Ebay that accepts $aud but it does not look like the mech that I have pulled out.
would live some help thanks
Re: x-Arcade coin door
« Reply #1 on: September 22, 2014, 04:44:44 pm »
Do you have a pic of the coin mech?
Edit:  Found this on Xgaming's website:
http://na.suzohapp.com/all_catalogs/coin_doors&C=1&R=All&S=TS&FILTER_NAME=COIN_DOOR_PRODUCTS&FILTER_VALUE=Coin%20Mechs
Apparently it uses Suzo-Happ parts.  There are many to choose from at that link.  Once you decide on which you need, simply search for the part number on e-bay.
DeLuSioNaL29
« Last Edit: September 22, 2014, 04:59:31 pm by DeLuSioNal29 »
fr_303
  • 1st cab done!!!
« Reply #2 on: September 22, 2014, 06:33:56 pm »
mgb
  • North East, US
« Reply #3 on: September 22, 2014, 06:40:46 pm »
Coin mechs are pretty universal and that shown in the ebay link looks like a typical one to me.
Can you post a pic of the one you have? Is it a happ one
fr_303
  • 1st cab done!!!
« Reply #4 on: September 22, 2014, 06:45:52 pm »
I am tring to upload a pic but am struggling from my phone :banghead:
The main difference I can see with mech is there are 4 (positioning lugs) 2 on each side on my one but there only seems to be 2 on this ebay one will this affect it?
fr_303
  • 1st cab done!!!
« Reply #5 on: September 22, 2014, 06:51:01 pm »
This is my mech
« Last Edit: September 22, 2014, 06:53:16 pm by fr_303 »
mgb
  • North East, US
« Reply #6 on: September 22, 2014, 06:56:38 pm »
Lugs may be removed depending on what they're being installed in.
For instance, they may come with 4 lugs and if your mounting it in an older style door, it may mount up against the door, then you'd remove a certain two lugs. Where a typical over under door, they mount perpendicular and the other 2 lugs would be removed instead.
Some times the lugs screw on or off. Other times you need to bresk off the unneeded ones.
I hope that helps.
Google it, you'll see what I'm talking about.
As a matter of fact, I think bob roberts has an article and he's a hell of a lot better at explaining it
  • Last login:Today at 07:37:58 am
« Reply #7 on: September 22, 2014, 07:12:35 pm »
http://www.therealbobroberts.net/cm.html
« Last Edit: September 22, 2014, 07:14:58 pm by PL1 »
mgb
  • North East, US
« Reply #8 on: September 22, 2014, 07:25:55 pm »
Yeah, that looks like the one, thanks Scott
