Author Topic: Spinner settings in mame  (Read 1446 times)
Connorsdad
  • Last login:May 18, 2024, 04:28:42 pm
« on: September 14, 2014, 12:52:40 pm »
My spinner controls cars like crap in racing games, I've tried many different settings but I can't seem to get it right. It seems way too sensitive, the cars seem to go all over the place. May be it's because I'm not using the wheel add on ?
What settings do you guys use ?
DarthMarino
  • Last login:September 06, 2025, 02:38:47 pm
Re: Spinner settings in mame
« Reply #1 on: September 14, 2014, 01:29:41 pm »
It's going to be different for every day.  You tried lowering the Dial Sensitivity and the Dial Digital Speed?
  • Last login:Yesterday at 12:10:06 pm
« Reply #2 on: September 14, 2014, 01:44:36 pm »
First off, don't map Dial LEFT and Dial RIGHT.
That would have the same effect as the spinner being a button that is pressed as soon as it is turned left or right.
Only map Dial Analog X.
Second, the only adjustment under the analog menu in MAME that you need to worry about is SENSETIVITY.
The adjustments that contain the word DIGITAL are for when you are using buttons in place of an analog control.
Example: you are using buttons in place of the original analog pedals, but the car in Pole Position squeals the tires and loses time whenever you start out.
Lowering DIGITAL speed will reduce the speed at which the virtual analog control is depressed when you hit the button, instead of being instant-on.
Changing DIGITAL centering will alter the speed at which the virtual analog control returns to center when you release the button.
« Reply #3 on: September 14, 2014, 01:52:24 pm »
geecab also came up with a modification to the MAME source code that makes the 270 degree wheel games play nicer with 360 degree wheels.
http://forum.arcadecontrols.com/index.php/topic,130956.msg1341623.html#msg1341623
Connorsdad
« Reply #4 on: September 20, 2014, 05:37:38 am »
Thanks BadMouth, I'll try those adjustments, as for building my own mame from source I'll leave that to the experts :)
