January 31, 2026, 02:46:32 pm
Did not see the shipping charges, and yes, that does kill the deal a bit. I just haven't seen any decent non-widescreen IPS panels in a while anywhere.
You should double check because I believe the P190S is a TN panel. At least the ones I've purchased in the past are. I know Dell used to be in the habit of mixing different panel types under the same model number. However, If you are looking for a good 19" IPS panel I did find one that is currently being made, the LG 19MB35. It is a commercial monitor, but you can get it at newegg for $160 new. I did buy one and it is inface a IPS panel with awesome views from all angles. And it looks much better than the PVA panel it just replaced! I mentioned it in the thread on the monitor forum here: http://forum.arcadecontrols.com/index.php/topic,141208.0.html
The lg 19MB35 I mentioned is a 5ms IPS panel. Still have to test the lag though, but i can't detect any durring play.
Response Time 5ms (G to G)
Quote from: Unstupid on September 15, 2014, 02:05:43 pmThe lg 19MB35 I mentioned is a 5ms IPS panel. Still have to test the lag though, but i can't detect any durring play.Yes but LG's marketing measures reponse time in GTG where others use Black to White to Black which would always be longer so the reported time is a bit misleading.QuoteResponse Time 5ms (G to G)
