Author Topic: My first C/P design.  (Read 1372 times)
sin360
  • Last login:May 11, 2023, 11:12:23 am
« on: September 12, 2014, 12:39:14 am »
Hello everyone,
I'm starting to work on my first mame cabinet. This is my current c/p design that I'm thinking of going with it's 47"X16". It a 4 player setup with a trackball which is green and the red circle will be the spinner. I've setup the joys so smash tv will be playable as well. I would like all suggestion and constructive criticism.
dubstylee
  • Last login:November 25, 2014, 11:01:07 pm
Re: My first C/P design.
« Reply #1 on: September 12, 2014, 12:48:28 am »
It is good that you didn't try to rotate the P3/4 controls.  That was my biggest issue with trying to build a 4 player panel, and ultimately I opted for a 2 player control panel.  Best advice anyone gave me though, was to mock it up on cardboard and make sure all of the controls feel comfortable.  Good luck!
DaveMMR
« Reply #2 on: September 12, 2014, 07:54:19 am »
Pretty good but of course make sure things aren't too tight by testing it.  You could always rearrange the outer-player buttons above/below the stick if necessary (like a lot of 4P games did.)  It it good you have the sticks lined-up though so you can add Smash-TV, Total Carnage, et al.
The trackball and spinner placement do seem a bit odd - maybe you can move the spinner above player 2's buttons so it doesn't look so isolated?
sin360
« Reply #3 on: September 12, 2014, 10:35:30 am »
That looked like a good spot for the trackball. I was trying to place it with good space around it so nobody smacks there hand on anything.  Yeah the spinner does looked kind of lonely.
