Author Topic: ROWE AMI R87 JUKEBOX  (Read 4780 times)
piperdoon
  • Last login:October 01, 2014, 04:05:17 pm
« on: September 11, 2014, 09:31:12 am »
I have a rowe r87 jukebox.everything works ok apart from one thing when i press selection buttons for a record nothing happens. If i press the scan and cancel button on mech  it picks up a record an play it ok and then returns it ok.The carousel turns round and plays the the next record the only way to stop it if i put service switch from on to service.Does anyone knows whats wrong.I would just like to push selection buttons to listen to a record and not having to push the scan button to play a record.M
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: ROWE AMI R87 JUKEBOX
« Reply #1 on: September 12, 2014, 07:26:55 am »
Hello Piperdoon,
Welcome to the forum.
I suggest that you send the following boards to a Rowe Specialist for testing/repair:-
Central Control Computer (CCC) 608870-01 (the revision number can be up to -06)
Mechanism Control 4-07221-01 (the revision number can be up to -05)
Pricing Board 6-08878-01 (the revision number can be up to -05)
If you were in the UK or Europe I would suggest that you send them to me testing/repair.
If in the USA then I suggest that you send them to AB Leisure.
Regards
Alan
Alan Hood
ami-man
alan-hood@datex.co.uk
piperdoon
« Reply #2 on: September 12, 2014, 05:04:21 pm »
thanks for your message about sending central control computer,pricing board mech computer.I do live in the uk so i could send them to you,do you have a rough estimate it would cost to have them tested and repaired.many thanks John.ER
ami-man
« Reply #3 on: September 15, 2014, 09:35:23 am »
Hello John,
It was good speaking to you this morning, I look forward to your boards arrival tomorrow.
Regards
Alan
Alan Hood
ami-man
piperdoon
« Reply #4 on: September 15, 2014, 04:22:51 pm »
thanks Alan it was good speaking to you hope theres nothing to drastic with the boards,JohnXAEX
piperdoon
« Reply #5 on: September 17, 2014, 02:08:37 pm »
Hi Alan, thanks for servicing my boards got them back today fitted them back in powered the box up and hey presto its playing all the selections properly both A&B sides. I would like to thank you so much for your experience on this.I can now crack on putting it all into my continental replica box i built.Once again thankyou so much John. :applaud: :) :)
piperdoon
« Reply #6 on: September 24, 2014, 03:26:02 pm »
Stripped my old juke box down  and transferred it into my ami continental replica all works fine except i noticed a black wire coming from speaker crossover .there are 3wires coming from cross over 2 goes into amp but not sure where black lead goes could it possible for it to go to earth as the speakers seem to be working fine
ami-man
« Reply #7 on: September 25, 2014, 11:19:06 am »
Hello John,
Send me some pictures direct to my email address and I will give you tips about the wiring.
Regards
Alan
Alan Hood
ami-man
UK
