Author Topic: Groovy arcade Double image  (Read 3370 times)
wman
  • Last login:April 23, 2015, 02:51:46 am
« on: September 09, 2014, 01:48:35 am »
So i have tried Groovy arcade i can get to the point where i should i have proper 15khz and all i see is double image, i can start the front end even the games which are properly displayed on single screen in correct resolution.My card is geforce 6200 le works well with soft 15khz.The question is why the double image seem like card isnt suported but then i can launch the games just fine so why the double image.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
Re: Groovy arcade Double image
« Reply #1 on: September 09, 2014, 09:52:13 am »
are you using a 27/29" Makvision monitor? I've found they don't like to display interlaced resolutions, and the image ends up looking like it's got a really fast vertical jitter or blurry double image when you try to use one of those modes.
wman
« Reply #2 on: September 09, 2014, 01:14:59 pm »
No i'm not using makvision monitor.I'm on pal tv using vga scart cable.The question is why it isn't working i have interlaced modes in win xp just right no problem here.It just shows groovy arcade main menu screen in low res but double image.I really don't know why.
  • Last login:January 23, 2026, 06:10:10 am
« Reply #3 on: September 11, 2014, 03:49:03 am »
Hi wman,
I had the same issue when testing an old Nvidia card I have around (GeForce4 Ti 4200). I believe the problem is that the open source Nvidia drivers ("nouveau" drivers) we use in Linux don't support interlaced modes. Trying to set an interlaced mode results in the two fields being shown one on top of the other.
The only workaround I can think of is forcing a progressive mode in the kernel boot line. I haven't tested this however.
wman
« Reply #4 on: September 12, 2014, 01:58:10 am »
Hi calamity
Well i was thinking that the main menu in the groovy arcade is low res at least thats what my card display.If its really interlaced than im unlucky, ati card would solve my problem but its not easy to get the right one.
What about testin the progressive resolution would that be an issue.
wman
« Reply #5 on: September 20, 2014, 01:02:30 pm »
Wll i got an ati radeon x300 and i have clear picture now not double and its really interlaced.By the way good job on GroovyArcade.But now i have different problem my volume is really low tried setting in the setup does not help.I mean extremely low anyone any help.
Sledge
  • Last login:August 02, 2025, 01:37:53 am
« Reply #6 on: September 21, 2014, 06:52:26 am »
You need to tell us how you have it hooked up..
Are you going through any sort of AMP?
wman
« Reply #7 on: September 21, 2014, 10:49:47 am »
I have no amp setup here.The setup i have is 3.5 Mm jack from vga scart cable pluged straight to onboard sound card so i have sound from tv. That is all any help would be great
