Author Topic: Issue with Nanao MS9  (Read 2743 times)
Andypc
  • Last login:November 18, 2024, 01:45:58 pm
« on: September 07, 2014, 07:51:39 pm »
I am having an issue with the MS9 in my Egret 2. The chassis has been services with new caps fitted. The picture is great apart from a really annoying wobble in the bottom left and right hand corners of the screen. I have done everything I can think of to try and resolve it. The whole monitor has been out the cab and set-up by Gunblade. The loom has been checked, everything that could cause problems has been switched off / removed. Could this be a problem with Groovymame?
ReelTechnoFreek
  • Last login:August 18, 2018, 04:49:58 pm
Re: Issue with Nanao MS9
« Reply #1 on: September 08, 2014, 01:43:29 am »
Andy, does the wobble only appear in mame or is it on everything, desktop other pcbs etc?
What sort of transformer is in your cab?
  • Last login:Today at 02:25:21 am
« Reply #2 on: September 08, 2014, 01:55:10 am »
From his other thread:
I am having an issue with the MS9 in my Egret 2. The chassis has been services with new caps fitted. The picture is great apart from a really annoying wobble in the bottom left and right hand corners of the screen. I have done everything I can think of to try and resolve it. The whole monitor has been out the cab and set-up by Gunblade. The loom has been checked, everything that could cause problems has been switched off / removed. I am running Groovymame, but it is also present when using a pcb.
ReelTechnoFreek
« Reply #3 on: September 08, 2014, 02:20:28 am »
Cheers Scott.
My question about the transformer still holds so!
  • Last login:Today at 02:29:35 am
« Reply #4 on: September 11, 2014, 03:57:56 am »
Hi Andypc,
The problem is not from the software side, that's for sure.
twistedsymphony
  • Last login:February 03, 2024, 11:13:51 pm
  • Play stupid games... win stupid prizes.
    • solid-orange.com
    • CollectorsEdition.org
« Reply #5 on: September 11, 2014, 09:06:16 am »
If ht happens with a PCB then it's definitly not software related.
have you tried unplugging the built in degausser? are there unshielded speakers near by the monitor? are there any power lines run near the tube like perhapse AC lines for a marquee lamp?  I've seen all of those things cause wobble in a monitor.
stellarola
  • Last login:June 24, 2020, 11:46:59 pm
  • .::For the love of the game::.
« Reply #6 on: September 15, 2014, 11:24:03 am »
Try adjusting the flyback?
« Last Edit: September 15, 2014, 08:25:24 pm by stellarola »
