Author Topic: RGB Illuminated pushbutton outer ring with solid plunger?  (Read 4687 times)
Jakobud
  • Last login:Today at 05:44:25 pm
« on: September 04, 2014, 05:51:54 pm »
In my future cabinet I'm planning on doing RGB LED buttons. However I remember seeing some buttons someone did where they used a translucent pushbutton and replaced the middle plunger with a normal opaque color button so that only the outer ring is what lights up. Anyone have links to this or some video on how it looks, etc?
Re: RGB Illuminated pushbutton outer ring with solid plunger?
« Reply #1 on: September 04, 2014, 05:59:48 pm »
The Beast.
Now everybody has the luxury of buying them already assembled through Paradise Arcade.
Generic Eric
« Reply #2 on: September 04, 2014, 06:39:13 pm »
The Beast.
Great.  Now they do.  I wish i would have thought to ask for that.
You are welcome to look at my cp to see what the buttons look like without an LED in them.
  • Last login:Today at 05:25:44 pm
« Reply #3 on: September 04, 2014, 07:35:35 pm »
It would be nice to have black-rimmed LED (either single-color or RGB) admin buttons with diffusers and decent-sized inserts that are close to the same profile as the player buttons instead of these sawed-off volcano-wannabe's.  :(
You can mix-and-match IL buttons, but the insert size is 56% smaller -- 0.640" (0.321536 sq. in.) instead of 0.850". (0.5671625 sq. in.)
How hard can it be to get the body of the buttons that almost every vendor carries (below) cast in black plastic? (No new mold needed.)   :soapbox:
[/rant]
« Last Edit: September 04, 2014, 07:41:41 pm by PL1 »
SavannahLion
« Reply #4 on: September 04, 2014, 10:17:40 pm »
Wait.... the illuminated buttons are a different profile than the standard arcade buttons? I thought they were all the same profile??
Whose button is in the middle?
« Reply #5 on: September 04, 2014, 11:08:08 pm »
The people who would notice are the same ones that look at a DK cab and immediately notice that the buttons are repros (like the orange) because they are 1mm shorter than the originals. (like the blue)
They are very close, but the bezel on the LED is more angular, where the bezel on other pushbuttons (IL/Arcade Prime/Goldleaf/Sanwa/Seimitsu) are more round.
Left to right: GGG Arcade Prime, Paradise White Convex LED Lighted Arcade Pushbutton, Paradise White Black Rimmed Convex LED Lighted Arcade Pushbutton.
I can live with them being in the same ballpark, but the one on the right isn't even the same sport.   :lol
« Last Edit: September 04, 2014, 11:15:56 pm by PL1 »
  • Last login:October 09, 2025, 01:32:01 am
« Reply #6 on: September 04, 2014, 11:15:09 pm »
I've decided it's IL/Happs, or nothing. I had the middle ones and ultimately didn't care for them.
« Reply #7 on: September 04, 2014, 11:24:21 pm »
They're great for admin buttons with inserts, but I wouldn't want to use one as a fire button for Galaga.
Jakobud
« Reply #8 on: September 05, 2014, 12:46:37 pm »
The Beast.
Can you paste the link? They have a lot of buttons, I'm not sure which is which.
Also, on the Beast, when you have the player 1/2 start buttons, do the little white player icons light up at all?
Generic Eric
« Reply #9 on: September 05, 2014, 12:50:51 pm »
The Beast.
It is in his sig
http://forum.arcadecontrols.com/index.php/topic,108719.0.html
« Reply #10 on: September 05, 2014, 01:36:06 pm »
The Beast.
Here you go: http://www.paradisearcadeshop.com/&ui-page=0-56#/324-il-translucent-buttons
And no, the player icon imprints do not light up.
Jakobud
« Reply #11 on: September 05, 2014, 01:43:48 pm »
The Beast.
It is in his sig
I mean't the link to the buttons on Paradise. But thanks!
Jakobud
« Reply #12 on: September 05, 2014, 01:50:47 pm »
Okay so I found the buttons here: http://www.paradisearcadeshop.com/324-il-translucent-buttons
How does this work regarding assembly? You need this: http://www.paradisearcadeshop.com/il-translucent-buttons/809-clear-il-translucent-pushbutton-psl-l.html
And then what do you use for the LED? I see an option to use this ring: http://www.paradisearcadeshop.com/button-leds/580-pele-30mm-led-rings.html
Or this (http://www.paradisearcadeshop.com/button-leds/100-il-lumination-rgb-5vdc-led.html) which I assume goes inside the pushbutton?
On that ring, why are there so many leads? I am counting 8 connectors... The ring has 2 LEDs, is that so you can light up each one with different colors?
Anyone have pictures of these products in action?  I curious as to the visual difference between the ring vs the internal LED solution. Also I'm curious on what it looks like with the 2 ring LEDs being two different colors.
lamprey
« Reply #13 on: September 05, 2014, 02:20:27 pm »
Not the cheapest option, but GGG (Groovy Game Gear) has Clear pushbuttons. I don't think they are on the website, but you can email them for availability. If you combine that with black (or whichever color you want) pushbuttons you can achieve the same effect. As far as I know, GGG doesn't offer the option to combine clear with a colored button like Paradise Arcade Shop. But, you might ping GGG to see if that is an option or not.
Generic Eric
« Reply #14 on: September 05, 2014, 02:51:55 pm »
The Beast.
It is in his sig
derp.
« Reply #16 on: September 06, 2014, 12:45:11 am »
Have you looked through the LED button roundup thread here?
It shows an earlier version of the IL-lumination LEDs and the Pele rings.
