Author Topic: FE vertical and Mame vertical  (Read 1382 times)
mtd
  • Last login:December 13, 2003, 04:15:46 pm
    • MurderousTreacherousDogs
« on: December 11, 2003, 01:47:09 am »
I've tried Game Launcher, 3Darcade, and others . . . but still can't get both MAME and the FE to run vertical.
If I use mame 32 I can get mame to play the games vertical, but these FE's don't use mame32.  So, I try command line Mame and have no luck.  I can get the FE's to load vertical, but as soon as the game is launched it is launched horizontal.
I am using a 19" Eygo VGA monitor that is only capable of 640x480, so PivotPro, Nvidia, ATI rotation is out of the question.
Any advice?
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
Re:FE vertical and Mame vertical
« Reply #1 on: December 11, 2003, 02:17:59 am »
-set rol or ror to 1 in mame.ini
or
-add some commandlines to your fe's mame emulator setup
for 3darcade for example:
10|mame|-rol|
if your monitor is rotates then
-use mames autorot option in mame.ini
or
-make a copy of mame.ini and call it vertical.ini and in it set rol or ror to 1
or
for 3darcade:
15|vertical|-rol|
peter
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
« Reply #2 on: December 11, 2003, 12:48:11 pm »
Why?  Hardware doens't rotate at that resolution?
mtd
« Reply #3 on: December 11, 2003, 06:43:51 pm »
Thanks. . . I was adjusting the mame.cgf file not the .ini file for vertical rotation.
Yes.  Much to my dissapointment my Nvidia and ATI cards won't rotate at 640x480 -- I receive an error message that states that rotation isn't allowed at the selected resoloution.
As for Pivot Pro, when attempting to rotate I either lose the necessary resolution to run vetical games or it will only run games in a windowed mode.  I haven't been able to work around it.
« Last Edit: December 11, 2003, 06:44:31 pm by mtd »
mtd
« Reply #4 on: December 11, 2003, 09:17:50 pm »
Anyone able to help me set this up for Glauncher or Emuxalian?
I can get it to rotate now, but if I escape out of a game, glauncher crashes.
« Last Edit: December 12, 2003, 09:41:48 am by mtd »
