Author Topic: Which encoder for a driving game?  (Read 2067 times)
southpaw13
  • Last login:August 17, 2025, 03:18:15 pm
  • Whatever!
« on: August 23, 2014, 01:23:18 pm »
Got a gutted driving game.  2 steering wheels, 2 gas pedals (using pots), 6 buttons.  Which is the best encoder to get?
Slippyblade
Re: Which encoder for a driving game?
« Reply #1 on: August 23, 2014, 01:58:04 pm »
I'm a fan of the Kade, but you'd need to use the mysterious and (apparently) not available Kade+ to interface analog controls.
That actually begs a question, are there any off-the-shelf analog encoders?
(edited for spelling - oops)
« Last Edit: August 23, 2014, 04:17:55 pm by Slippyblade »
« Reply #2 on: August 23, 2014, 03:28:06 pm »
I'm a fan of the Kade, but you'd need to use the mysterious and (apparently) not available Kade+ do interface analog controls.
I always figured that if I did MAME my racing cab, that I'd use one of these:
http://www.ultimarc.com/a-pac.html
southpaw13
  • Whatever!
« Reply #3 on: August 23, 2014, 03:48:33 pm »
That's nice!  Does it have input for a trackball which is the steering wheels?
« Reply #4 on: August 23, 2014, 03:52:38 pm »
Well, if I were doing a trackball, then I'd go this route...
http://www.ultimarc.com/optipac1.html
southpaw13
  • Whatever!
« Reply #5 on: August 23, 2014, 04:04:01 pm »
Ok.  So who sells one that does both optical (steering wheels) and analog (pots) ???
« Reply #6 on: August 23, 2014, 04:13:24 pm »
PM AndyWarne. He runs Ultimarc and might be a great source.
adder
« Reply #7 on: August 23, 2014, 04:28:43 pm »
maybe this below, perhaps andy warne can confirm
http://www.u-hid.com/home/index.php
« Reply #8 on: August 23, 2014, 04:38:36 pm »
Yeah, I was going to post a link to the U-HID, but I really don't know much about it.
  • Online Online
  • Last login:Today at 09:01:41 pm
« Reply #9 on: August 24, 2014, 12:42:32 am »
Assuming that the steering wheels are 360 optical instead of potentiometer.
You'll need connections for the following:
  * 4 optical inputs - 2 optical steering wheels
  * 2 analog inputs - 2 gas pedals
  * 8 digital inputs - 6 buttons, 2 coin slots
  * 5v
  * GND
AFAIK, U-HID is currently the best for optical and analog on one board, but it's priced accordingly.
The U-HID Nano or U-HID-G (used one in the pin controller -- see sig) is a less expensive choice, but they only handle 8 inputs.
KADE has two beta optical firmwares for the miniArcade/microArcade/Minimus AVR.
One assigns the non-optical inputs to keyboard keystrokes and the other assigns them as gamepad buttons.
For KADE analog, you'll need either one of the prototype KADE+ boards or you can use the KADE+ spinoff KADESTICK. (see sig)
Right now, your best (and easiest) solution is probably to use two encoders, a U-HID Nano for the optical+analog and another inexpensive encoder for the buttons.
« Last Edit: August 24, 2014, 02:36:33 am by PL1 »
southpaw13
  • Whatever!
« Reply #10 on: August 24, 2014, 02:18:55 am »
The game only has 6 buttons and 2 more for coin so it might work !!!
  • Online Online
« Reply #11 on: August 24, 2014, 02:41:11 am »
If you want an inexpensive source for the minimus AVR and don't mind soldering wires, check out this thread.
southpaw13
  • Whatever!
« Reply #12 on: August 24, 2014, 03:15:29 pm »
I think it is a little too mimimal for me.  Probably going to try the U-HID.
Thanks!!!
