Author Topic: What Kinds of Switches Can I-Pac Handle?  (Read 3243 times)
TPA5
  • Last login:May 30, 2017, 10:25:16 pm
  • Wanting A Cab
« on: August 15, 2014, 02:34:18 pm »
Hey folks,
I've been getting into playing space sims/combat games more often, and a  thought came to me. (A rare occasion  :P)
I want to build a space-sim styled control panel that can be used for games such as Wing Commander, Orbiter Space Sim, Pioneer Space Sim, Kerbal Space, Elite: Dangerous, etc. I'm working on a Google Sketchup mockup, but I haven't used that program in so long it's kind of slow going. Besides, I still need to figure out exactly how many switches and where to lay them out. However I already know some of the types of switches I will need, which brings me to a question about the I-Pac.
But first, the switches...
Rotary switches:
The classic toggle switch (some covered, of course!):
Momentary switch:
The rest of the switches I would need are simple button-style, which I know the I-Pac can handle.
My question is, does anyone know if the I-Pac can handle the other types of switches? It would certainly make the interfacing on the control panel more convenient!
Thanks guys!
  • Last login:Today at 01:44:44 pm
Re: What Kinds of Switches Can I-Pac Handle?
« Reply #1 on: August 15, 2014, 05:05:15 pm »
When you connect ground to the input on IPac and other active-low encoders (KeyWiz, KADE, etc.), it completes the circuit, allows current to flow, and outputs the associated keystroke.
Momentary switch:
Electrically, it works exactly the same as a microswitch.
The normal IPac firmware will press and hold the key for as long as the switch is in the "on" position.
May or may not cause a problem with the software -- test before you commit to including these switches.
You may be able to modify the KADE firmware to send a single keypress when you close the switch and send another when you open the switch.
Rotary switches:
Like the toggle switch, a rotary switch used with the normal IPac firmware will press and hold the key of the selected input.
You may also be able to modify the KADE firmware to send a single momentary keypress based on the switch position.
The GP-Wiz40 and KADE both have a mechanical rotary joystick function/firmware (details here) that only outputs a right/left keystroke when the rotary switch changes position clockwise/counterclockwise.
« Last Edit: August 15, 2014, 05:16:39 pm by PL1 »
TPA5
  • Wanting A Cab
« Reply #2 on: August 18, 2014, 11:44:58 am »
Momentary switch:
Rotary switches:
Awesome, thank you for all the information! I hadn't really heard about the KADE, that appears to be an even better option for this project. I will do some research and see if that could work. Thanks again, that's a big help!
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #3 on: August 22, 2014, 04:09:53 am »
Our U-HID board is designed for this type of mix of controls. It can handle pots and also you can configure any switch to send a pulse of keypress when the switch is closed or opened and remains in the new state. There are also advanced modes which send a different code when the switch is closed and opened etc.
www.u-hid.com
