Author Topic: Is this bad? Can't tell if these are fried????  (Read 3106 times)
thk
  • Last login:December 13, 2015, 11:00:09 pm
  • KEEP MOVING FORWARD
« on: August 15, 2014, 11:37:07 am »
Ok so I am trying to get a multimeter because I know that will probably help me but can someone tell me if these things are fried or what? I have attached the pics below of my galaga bootleg that I am trying to fix. Thanks
“The truth is, everyone is going to hurt you. You just got to find the ones worth suffering for.”
― Bob Marley
sollyscomputers
  • Last login:March 06, 2019, 01:31:51 am
  • Jukebox? check! Now on to cocktail cab
    • Softweb Developments
Re: Is this bad? Can't tell if these are fried????
« Reply #1 on: August 15, 2014, 04:52:09 pm »
If you're asking whether the electrolytic capacitors are fried, they usually 'pop' or bulge on the top when they blow but not always true.  Only way is to use a capacitence meter (these days most multimeters have them) and check them.  I recommend removing them from the board before you test to get an accurate reading as if you test while in circuit, other components may change the caps value
Hope this helped abit
Slippyblade
« Reply #2 on: August 15, 2014, 05:43:14 pm »
I'm gonna go out on a limb here and say the one that is missing half the component is probably no good.   :applaud:
thk
« Reply #3 on: August 15, 2014, 09:15:18 pm »
Ok last question then...
Would this cause the game to not boot? The transistor?
― Bob Marley
Slippyblade
« Reply #4 on: August 15, 2014, 09:20:38 pm »
That busted piece is a capacitor, not a transistor.  Sorry, not sure about how it would affect boot process.
ed12
« Reply #5 on: August 15, 2014, 09:57:48 pm »
the 104k/j is a buss by-pass cap..no biggie right now
just remove it for now..the buss will live
the other's :electrolytic's: shear age say's replace them
1981/2 is when that board came out
thats a boat load of time ago...there aged and old
ed
matsadona
« Reply #6 on: August 27, 2014, 04:48:54 am »
I second that  ;D
As stated by others, that obviously broken capacitor is not a critical part, however it might cause "glitches" when missing.
Here you can find more information about this topic:
http://www.brighthubengineering.com/diy-electronics-devices/56501-how-to-decouple-a-logic-circuit/
