Author Topic: CP spacing (joysticks relative to buttons, etc)  (Read 1914 times)
mmmPeanutButter
  • Last login:December 20, 2020, 07:49:09 am
  • better living through gaming
« on: December 10, 2003, 10:21:02 am »
I'm planning my layout for my CP.  I've sort of lined up getting an empty cab with an inside width of 24".  Originally, I had planned a slightly wider cab (primarilly for a rotating monitor, but I should be ok with the 24") but now I need to see if I have enough room on the CP.
The top drawing is what I think I have to go with just because of the space.  The 7-button layout is nice, but adds 1.5" to each set of buttons.  I think I would rather have slighly less playability on some neo-geo games in order to have better playability on the rest (because of more room).
So the question is:
Are there standard (or ideal) spacing for either A,B, C, or D?  I think B and C are probably the most improtant.  Ultimately, I guess it is a matter of preference, but I wouldn't mind some suggestions before I build my mock-up.
And would you agree with me on the removing-the-seventh-button plan?
Thanks for your help.
Chris
    • Chris's MAME Cabinet
Re:CP spacing (joysticks relative to buttons, etc)
« Reply #1 on: December 10, 2003, 12:40:37 pm »
If your control panel connects to the machine with panel clamps, you may not have left enough room at the sides for the clamps' strike plates.
--Chris
mmmPeanutButter
« Reply #2 on: December 10, 2003, 12:52:19 pm »
There are panel clamps towards the back, and a piano hinge on the underside of the front (it's a metal cp).  There are (3/4"?) wood supports on the sides of the cab, but if I need to go close to them, I could always use a router to give me a little room...   so the 24" is available room.
aricade
  • Last login:August 15, 2004, 01:38:26 pm
  • Wamma langa ding dong!
    • Isaacade
« Reply #3 on: December 10, 2003, 01:09:54 pm »
for your neo geo games just use buttons 1,4,5,6
First arrangement seems fine to me..  but if you plan to hook up an xbox , ps2, gamecube then you might want more buttons  (8 is ideal)...
decisions decisions
Off all the things I've lost I miss my mind the most!!
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #4 on: December 11, 2003, 02:03:34 am »
if you think you'd go for beatmania games, the seventh button will allow you to play more than 60% of the songs.  (many require seven keys, a lot only need 5.)
But if you're playing beatmania on it you need to rethink the button design anyway, so that you can play the buttons like a piano if you need to.
(just a thought - there really aren't that many beatmania players on BYOAC)
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
