Author Topic: Wire from Jamma. connect side  (Read 1207 times)
DOC
  • Last login:June 30, 2004, 07:16:06 pm
  • I walk in the dark... But why am i afraid?
« on: December 10, 2003, 02:41:28 am »
on the part side of my Jamma Connector there are "Wires" of course :) * but!! * on the other side of the connection the wires dosen't match in color - this may be cause of it's a home created CP circuit... :)
now, question is : would you rewire everything and make wire color match?
Learn we must.. Use the force... Abuse blonde woes...!!
Tailgunner
Re:Wire from Jamma. connect side
« Reply #1 on: December 10, 2003, 02:49:42 am »
I would, but only because building wiring harnesses is part of what I do for a living. ;) Several people have wired everything using one color, and to be honest their stuff seems to work just fine.
If it works, I'd suggest leaving it alone and concentrating on the stuff that doesn't. :)
DOC
« Reply #2 on: December 10, 2003, 03:16:32 am »
yes yes :).. of course it'll work..!! but it's a lil'confusing if u know :)...!! * hehe 'i'll just let it be as it is then *
i'll soon start building my own CP... hope you ready to support me if something goes wrong, " that be the wirepart of course  ;) "
OFF TOPIC " btw - the manual you gave me helped me out very very much * i've been able to identify everything in my cab now, and got no problems understanding anything of it :).. in fact the electronics in a cab is very simple...!!"
« Last Edit: December 10, 2003, 03:17:10 am by DOC »
Sephroth57
  • Poo Monkey
  • Last login:June 07, 2020, 11:17:00 am
    • Check it out!!!
« Reply #3 on: December 10, 2003, 10:59:57 pm »
link to the manual? i need to familiarize myself with the wiring also
"Owens is the ringleader in the ass hat circus"  D K
Tailgunner
« Reply #4 on: December 10, 2003, 11:04:13 pm »
Doc's using a Neo Geo cab, I gave him a link to a Neo Geo operator's manual at arcadedocs.
http://www.arcadedocs.com/vidmanuals/N/neogeo_mv1fz_manual.pdf
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #5 on: December 10, 2003, 11:57:53 pm »
ah ok, maybe i can find a diagram for my machine there. ( street fighter 3)
Sephroth57
  • Poo Monkey
    • Check it out!!!
« Reply #6 on: December 11, 2003, 12:15:52 am »
damn aparrently there is no main site for arcadedocs.com... hmmm
Tailgunner
« Reply #7 on: December 11, 2003, 01:57:16 am »
Try KLOV, if the manual is available there's a good chance they have a link to it.
DOC
« Reply #8 on: December 12, 2003, 03:10:08 am »
Klov...!! " go for it ;) "
