Author Topic: Colecovision Emulator  (Read 7261 times)
davidsz
  • Last login:October 09, 2004, 11:55:54 am
« on: December 09, 2003, 09:41:57 pm »
I am looking to add Colecovision to my growing list of emulators I am loading up into my Mame cab.  I am looking for recomendations from anyone who is using one.
The two  I have seen available and thier issues:
1) Virtual Colecovision for Windows 2.11a - This works really good has great sound but I cannot remap any keys to match my Mame cab.  Also has an issue since I need a combinations of chars to max the screen size.
2) Colem - I simply cannot get this one to run, it crashes and burns everytime I try it.
Any help is appreciated.
I am using Mamewah as a frontend.
Thanks,
David
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
Re:Colecovision Emulator
« Reply #1 on: December 09, 2003, 10:16:56 pm »
Thanks,
David
I use MESS (Multi-Emulator Super System).  It works great, and it emulates many different systems.  I'm currently using version 0.37 BETA 12 (Mar  3 2001).  Hmmm... It's time to download a newer version...
arcadecab
  • Last login:September 26, 2007, 06:17:06 pm
« Reply #2 on: December 10, 2003, 11:00:36 am »
I just tried MekaW for colecovision and it seems to work fine.  It has the option--as listed on Stuzza's website, in the .ini file to bypass the gui and load to full screen.  I also use it for SMS and Gamegear.  The only downfall is that it doesn't exit using escape--it goes back to the gui.  But perhaps Stuzza will fine a way around that at somepoint and then MekaW would work well with Colecovision with those options mentioned.
Zapper
  • Last login:October 07, 2006, 10:26:01 pm
  • The enemy's gate is down
« Reply #3 on: December 10, 2003, 01:34:33 pm »
The best Colecovision emu I've found for a cabinet is MESS 0.61.1, any newer version uses a new navigational gui which is cabinet unfriendly. MEKAW is not bad, if you download a program called MEKA Configurator you can set the emu to cabinet mode and it exits with escape.
"Three warps to the Bugger homeworld"
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #4 on: December 10, 2003, 02:09:45 pm »
you can diavble that gui in mess in mess.ini
### MESS specific options ###
newui                   0
As for the most accurate and with support for the driving wheel etc. is I think still adamem.
peter
davidsz
« Reply #5 on: December 10, 2003, 10:59:27 pm »
I tried Mess .77b and it seems to work pretty good so far.  I am using the DOS command line version.
My only issue is I cannot figure out how to remap the keyboard to be MAME keys?
Anyone know?
Thanks,
David
Zapper
« Reply #6 on: December 11, 2003, 01:40:30 am »
newui                   0
peter
Thanks for the tip )p(, now I'm up todate with MESS.
davidsz
Re:Mamewah and Colecovision Emulator
« Reply #7 on: December 11, 2003, 09:34:26 pm »
I figured out how to configure the keyboard - hit TAB for the menu.
I did run into a new problem with my front end - MameWah.
Mess is expecting the following:
Mess.exe coleco -skip_disclaimer -skip_gameinfo -cart c:\colecovsion\rom\donkeyk.rom
So in Mamewah I set it up as follows
Execueable: Mess.exe
Options: -skip_disclaimer -skip_gameinfo -cart
Rom dir: c:\colecovsion\rom
I get:
MESS.EXE c:\colecovsion\rom\donkeyk.rom coleco -skip_disclaimer -skip_gameinfo -cart
How can I make the options come before the rom path?
Also how can I stop it from using all caps?
Thanks,
David
SuperRabbit0
  • Last login:July 07, 2006, 08:53:30 am
« Reply #8 on: May 31, 2004, 11:51:11 pm »
Sorry, I am ressurecting this old thread because it seems to have most of the answers I pieced together from the MESS help pages.
For the life of me, I cannot get a Colecovision emulator running on my cabinet.  I want to use MESS because I can rotate it but no matter what I do in the games I cannot get the input menus to come up like in MAME.
I press 'TAB' and toggle Scroll Lock on and off and try tab with each setting.  No menu comes up like in the help screens and for these users.  I deleted default.cfg and all my games .cfg files and nothing.
What am I missing???
killbill
  • Last login:December 17, 2025, 04:32:58 pm
  • When I die, I want to go to arcade heaven!
« Reply #9 on: June 01, 2004, 07:03:50 pm »
Hi,
Could someone please post their MESS Mamewah cfg file?
For the life of me I can't can't seem to get Mess to run from Mamewah.
Thanks.
Chris
    • Chris's MAME Cabinet
« Reply #10 on: June 01, 2004, 07:24:46 pm »
My understanding is that MAMEWAH cannot put the options before the ROM name, only afterward.  Perhaps the answer is a batch file?  Make the "emulator" COLECO.BAT and have it contain:
Mess.exe coleco -skip_disclaimer -skip_gameinfo -cart %1
exit
This is just off the top of my head, I haven't tested it or anything...
--Chris
--Chris
SuperRabbit0
« Reply #11 on: June 01, 2004, 08:47:44 pm »
exit
--Chris
This is exacly how I have MESS running on Mamewah and it launches the games  perfectly BUT..................
for the life of me I cannot get the tab menu to come up (within Colecovision).  Have you been able to make that work (to configure your input keys)?
Zapper
« Reply #12 on: June 01, 2004, 09:20:16 pm »
I have MAMEWAH and MESS running in Win98, here's my Colecovision files. You'll need to edit all the paths. MESSWAH
EMU7.CFG - MAMEWAH FILES folder
MESS.ini - MESS ini folder
MESSui.ini - MESS folder
coleco.bat - MESS folder
coleco (shortcut) - MESS folder
  • Last login:Yesterday at 07:46:44 pm
« Reply #13 on: June 04, 2004, 06:29:09 pm »
I normally don't self-promote but....
If you guys want to try something new and don't want to fool with odd-ball bat files and other hacks, dk recently got the additon of a totally custom command line string.  I only mention it because this feature was added specifically to give better support for mess.  That copuled with my "Mess-ed" datfile and mame info generator, makes for the most painless setup of a "mess emulator" possible.
