Author Topic: oscar joystick restrictor question  (Read 1342 times)
ts
  • Last login:April 08, 2016, 03:01:29 pm
« on: December 09, 2003, 09:31:28 pm »
i have a super joystick from happs that just isnt cutting it in 4 way mode.  i mounted my joysticks from underneath the control panel so no mounting plate or screws shows.  is there any way oscars 4 way restrictor will work somehow with this setup or am i destined to have to buy a dedicated 4 way joystick...
thanks
Jakobud
  • Last login:November 18, 2025, 02:28:46 am
Re:oscar joystick restrictor question
« Reply #1 on: December 09, 2003, 11:07:20 pm »
Not sure if they will work with that setup.  Take a look at the T-Stick from Ultimarc.
Tiger-Heli
    • Tiger-Heli
« Reply #2 on: December 10, 2003, 06:48:44 am »
thanks
E-mail OSCAR - It's possible with that set-up if you can accurately drill the locating holes for the plates.  However, keep in mind that OSCAR ships his template plate with 1/4-inch fasteners to eliminate the "play" with 3/16-inch fasteners and you see how critical this is.
Another solution is the Omni-Stik (or Prodigy) from www.groovygamegear.com, or the J-Stik, T-Stik or E-Stik from www.ultimarc.com
