Author Topic: Newbie Question about Groovymame  (Read 3231 times)
Giddygoon
  • Last login:March 22, 2022, 04:13:04 am
« on: August 07, 2014, 08:19:36 pm »
I have just added your groovymame to my arcade cabs ( amazing !!! ) so smooth!!  And no lag
I'm am very impressed
because GM is adjusting the resolution and synch on the fly the Ini folder is empty... And I have a lot of games that are too loud...
Where do I edit the game volume separately
I have my GM mame ini file but it looks like a universal one setting for all
E.g Batrider way too loud on default
If you can help...
Keep the good work this is what the community has been waiting for
« Last Edit: August 09, 2014, 10:38:47 am by Giddygoon »
cools
  • Last login:August 19, 2025, 04:19:37 pm
  • Arcade Otaku Sysadmin
    • Arcade Otaku
Re: Newbie Question about Groovymame
« Reply #1 on: August 08, 2014, 03:12:39 am »
You can't.
Giddygoon
« Reply #2 on: August 08, 2014, 03:58:39 am »
What about if I create an specific INI file from my MameUIfx to adjust the volume of the audio per game then run via Groovymame?
Or will that upset all the GM auto settings....
I don't have a volume button my cab and some games like Nitro ball are ear cracking loud and others like
strikers 1945 are very quite on default
If anybody can help ( :
cools
    • Arcade Otaku
« Reply #3 on: August 08, 2014, 04:34:52 am »
If you create game specific ini files and override the universal volume setting in those you should be fine.
Giddygoon
« Reply #4 on: August 08, 2014, 06:11:04 am »
Kool  Cools
  • Last login:March 15, 2026, 04:39:26 pm
« Reply #5 on: August 08, 2014, 11:59:10 am »
Hi Giddygoon,
Do as Cools says. Remind to only add the specific options you want to override (with respect to mame.ini). In your case, just the volume options. If you just copy the full mame.ini and rename it as thegame.ini GM won't work properly.
Giddygoon
« Reply #6 on: August 09, 2014, 09:37:57 am »
Hi there,
Yeah, I copied my original INI files then just deleted everything apart from the sound section..... takes a bit of time to do but it works....
Volumes now balanced on my Shooter cab....
Thanks for your help and I have to say has made some games really come to life like i have never seen before.....
« Last Edit: August 09, 2014, 10:37:07 am by Giddygoon »
