Author Topic: Thomson 21" vga scart Newbie help  (Read 1362 times)
wman
  • Last login:April 23, 2015, 02:51:46 am
« on: August 06, 2014, 01:22:00 am »
Hi
I'm trying to connect pal crt tv thomson to vga scart would this cable do the job or i need something special http://www.alza.cz/hama-scart-d-sub-vga-d598104.htm. Not sure if the tv can handle 640x480 60hz what are my options i dont want to damage the set. I have already instaled soft 15khz and i cant see interlaced modes. So all and all would this work.
Paradroid
  • Last login:December 05, 2025, 10:28:19 pm
    • SCART Hunter
Re: Thomson 21" vga scart Newbie help
« Reply #1 on: August 06, 2014, 02:16:26 am »
Hard to say if the cable you linked to would be suitable without knowing how it is wired internally.
You need a cable that combines the horizontal and vertical sync signals from the VGA output. Without a composite sync signal, your TV won't sync to the computer.
Arcade Forge's UMSA will definitely do the job: UMSA - Ultimate SCART Adapter
My MAME/SCART/CRT blog: SCART Hunter
wman
« Reply #2 on: August 06, 2014, 02:39:26 am »
Edit
Alright i might try that, thanks for the help
Well after checking the umsa i think i couldnt fit power socket of the uk adapter but i i have found ready made cable online http://www.wolfsoft.de/shop/product_info.php/products_id/12836//vga-stecker-15pol.-%3E-scart-stecker-2m.html.But they dont ship to cz so if anyone from germany would do me a favor and send it to me.That would be great.Or if anyone have the correct cable to sell just PM me.
« Last Edit: August 06, 2014, 09:51:46 am by wman »
