Author Topic: Converting Happ UltimatCompetition actuator to the larger Super Happ stick size?  (Read 940 times)
tylerwerrin
  • Last login:May 13, 2022, 02:16:31 pm
Hi guys,
I have 2 Happ Ultimate Competition sticks & bases which work great - however, I purchased a couple LED ball top sticks, and their shaft is a different diameter than the Competition actuator is. I was wondering if anyone out there sells an actuator for the competition base which can be used with the larger diameter shaft of my new stick. I tried drilling the actuator out, but I don't have a bit between 3/8 and 1/2 -- 3/8" hole is ALMOST big enough to accommodate the new shaft but just not quite.
Any help out there? or is the only real answer buying a slightly bigger drill bit?
« Last Edit: August 06, 2014, 12:58:50 am by tylerwerrin »
