Author Topic: Rotating Cab Trackball Question  (Read 1342 times)
rdagger
« on: December 09, 2003, 06:04:24 pm »
This is a newbee question.  I have owned many computer trackballs, but not an arcade trackball.  On my computer trackball, the ball falls out when you turn it upside down.  Is this the case with Happ trackballs?  If so, how do you keep the ball from falling out if you have a rotating control panel?
If I go with a computer trackball, does anyone have any advice on how to keep the ball from popping out?
Richy
  • Last login:September 15, 2004, 09:04:53 am
Re:Rotating Cab Trackball Question
« Reply #1 on: December 09, 2003, 06:31:28 pm »
No the trackball stays in when it's upside down. More than half of it is below the top of the case. I don't know about the high ones.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 10, 2003, 01:26:08 am »
FWIW, ~0.6" on the normal & highlip 3" (or 1/5th or ball diameter), ~1" on the high ball (or 1/3rd), for the happs TBs.  Betson & wico are very close, if not the same, as the normal happs as far as amount of ball above top.
edit:
BTW, since this is for a rotating CP, it might be a good idea to open up your TB before mounting it, and look for any extra plastic, um, "flakes" left over from casting that should have bin sanded off.  Usually they are taken care of, but one small extra one scratched one of my balls when I turned the TB & ball over.  :-\  The "lip" the ball will rest should be smooth out of the box, so look at the surounding structure reenforcements.
« Last Edit: December 10, 2003, 01:35:14 am by u_rebelscum »
Robin
Knowledge is Power
