Author Topic: Help with NANAO MS8 setup @ 24khz  (Read 2997 times)
oilchanges
  • Last login:November 20, 2021, 04:48:46 pm
« on: August 04, 2014, 06:27:58 am »
Hi guys
I have to admit I'm a real beginner with this CRT stuff but I'm trying to get a Nanao MS8-26 @ 24kHz on a HD4870 running CRT_EMU win 7. I'm mainly aiming for sega model 2/3 and some nebula in 512x384 but maybe some pc games also if its possible.
I've followed all the instructions but am unable to find the desired resolution in windows or arcade ocd (1024x768@60i)
I have set vmmaker.ini set to EGA and also tried CUSTOM with the ms9 settings and have anycatalyst set to 1
I thought I was me so I removed all the video drivers and started from the beginning with the 15kHz jumper on the board and got it running without a problem just to test it, But now I went back to the 24kHz jumper setting and started fresh and same problem
If some one could walk me through were I'm going wrong any help would be greatly appreciated
Thankyou
  • Last login:February 19, 2026, 06:15:36 am
Re: Help with NANAO MS8 setup @ 24khz
« Reply #1 on: August 04, 2014, 06:35:59 am »
Hi oilchanges,
Have you checked inside Modelines.txt and seen the required modelines actually created?
oilchanges
« Reply #2 on: August 04, 2014, 06:54:56 am »
This may sound silly but I cant find a modelines.txt file anywhere where should i be looking?
« Reply #3 on: August 04, 2014, 06:58:31 am »
It should be in the same folder where vmmaker is.
oilchanges
« Reply #4 on: August 04, 2014, 07:02:20 am »
Hey mate just had a look and I cant find it in the folder would one not be getting created?
oilchanges
« Reply #5 on: August 04, 2014, 07:22:26 am »
ok so i just realised that you need to have the mame directories in the vmmaker.ini file to create modelines.txt file  :banghead: and all the modelines have been created where do i go from there?
« Reply #6 on: August 06, 2014, 01:50:32 pm »
Once the modelines are created (paste the contents of Modeline.txt here so I can check) then you should be able to use those resolutions, by means of ArcadeOSD.
