Author Topic: Issues using new VMmaker 1.3c vs 1.3b  (Read 1935 times)
bent98
  • Hyperspin Moderator
« on: August 02, 2014, 02:43:08 pm »
I have enclosed both the 13b and c ini files and a copy of dkong run with both vmmakesrs. I ofcourse rebooted to ensure the vmmaker  took effect.,
You will notice 1.3c dkong did not produce the desired effect.
I made adjustment to the .ini to match up with my oldini file from a few years back. I think you helped me with it. Theres one spot that jumps out at me.
1.3b:
; Minimum resolution values (these will be used instead of lower values)
   XresMin = 184
   YresMin = 192
;   XresMin = 512
;   YresMin = 400
1.3c:
   XresMin_XML = 184
   YresMin_XML = 192
   YresRound_XML = 4
   XresMin_Custom = 512
   YresMin_Custom = 160
   YresRound_Custom = 0
bent98
Re: Issues using new VMmaker 1.3c vs 1.3b
« Reply #1 on: August 02, 2014, 03:53:56 pm »
It helps when you read. :)   This fixed the Hyperspin issue. ModeTableMethod_XML = 2.
  • Last login:February 19, 2026, 06:15:36 am
« Reply #2 on: August 03, 2014, 01:06:29 pm »
Ok it looks like you already figured it out, anyway, as you see there are pairs of options with _custom and _xml endings. The _custom ones affect the resolutions taken from ReslList.txt, while the _xml ones affect the resolutions obtained from MAME xml.
