Author Topic: Kit Cocktail Cab (Complete Update Oct 20)  (Read 15560 times)
Unstupid
Re: Kit Cocktail Cab (Speakers) (Update Sept 9)
« Reply #40 on: September 10, 2014, 12:00:06 am »
The t molding is 3/4 cut down to 5/8 to fit the particle board which is 5/8 inch.   There is no 1 inch t molding on the cab.   The strip down the sides is 5/8.   Will look at the LG if I need a replacement but do not think it would fit in my $40 price range that my current monitor cost.
No the 1" filler piece on the CP sides... why did you cut into 2 pieces?
BobA
  • What Me Worry?
« Reply #41 on: September 10, 2014, 05:04:11 pm »
Oh that 1 inch.   I precut and notched the side pieces for the CP and they all turned out to be short that inch.   When the top is on the cab and no flash filling in the light then the fix is pretty well invisible.  Call me cheap  ;D
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
Re: Kit Cocktail Cab (Cabinet) (Update Aug 31)
« Reply #42 on: September 10, 2014, 09:11:01 pm »
19 inch 4:3 LCD monitor mounted to bottom of cocktail cabinet top.    The kit came with a mounting board already cut for VESA mount but I mounted to the top as It meant less fiddling to get the mounting board in the exact position.  Since it was an LCD weight was not a consideration.
i like how you mounted the lcd !  :applaud: what is the name of the metal strip used to mount it ? thanks  :cheers:
BobA
  • What Me Worry?
« Reply #43 on: September 10, 2014, 09:23:49 pm »
It is called Galvanized Strapping and available at home reno stores in the HVAC or Plumbing areas.
jmike
« Reply #44 on: September 10, 2014, 10:54:15 pm »
Yeah that stuff comes in handy. Here's a link:
http://m.homedepot.com/p/Oatey-3-4-in-x-10-ft-Galvanized-Steel-Tab-Tape-339892/100168794/
Home Depot also has these in plastic.
Loving the cocktail BobA.
  • Last login:Today at 06:18:12 pm
« Reply #45 on: September 10, 2014, 11:06:47 pm »
Add a fender washer to make room between the side of the PSU and screw head for tightening/loosening the screw and threaded inserts for easy removal and replacement.   :cheers:
mebronx2000
« Reply #46 on: September 10, 2014, 11:25:56 pm »
thanks :applaud: :applaud: :applaud:
mebronx2000
« Reply #47 on: September 10, 2014, 11:26:34 pm »
:cheers:thanks
BobA
  • What Me Worry?
« Reply #48 on: September 22, 2014, 08:10:58 pm »
Thanks for the comment JMIKE.
CPU, disk drive and amplifier mounted on door.   Running Maximus arcade with mame to test front end and mame setuup.
« Last Edit: September 22, 2014, 08:16:06 pm by BobA »
BobA
  • What Me Worry?
Re: Kit Cocktail Cab (CPU, HDD and amplifier) (Update Sept 22)
« Reply #49 on: September 22, 2014, 08:43:05 pm »
Just noticed it has not been 2 months yet.  Not bad considering the waiting time for some items to be delivered. Amp came from China, CPU, LCD and Speakers were local cabinet kit came from Toronto to Edmonton.
I tend to like clean cabs with very little in the way of graphics so once it is buttoned up and a top placed on it we will be 99% complete.  Any suggestions are welcome.
« Last Edit: October 20, 2014, 12:19:06 pm by BobA »
BobA
  • What Me Worry?
Re: Kit Cocktail Cab (Complete Update Oct 20)
« Reply #50 on: October 20, 2014, 12:17:51 pm »
Thanks Folks
Project Complete
