Author Topic: Audio issue with Lenovo laptop using custom monitor specs  (Read 2010 times)
Paradroid
  • Last login:July 12, 2025, 08:11:33 pm
    • SCART Hunter
« on: July 31, 2014, 07:06:44 am »
I have a really unusual (and frustrating) audio issue going on here...
I'm running GroovyMAME on my Lenovo W500 laptop (ATI Fire GL 5700 chipset / equivalent to HD 3650) connected to a UMSA adapter. I'm using a Hosa 3.5 mm to RCA adapter cable to route the audio from the headphone jack of my laptop to the UMSA. The onboard sound is provided by the Connxant 20561 SmartAudio HD chipset.
When I run GroovyMAME with a preset monitor spec (e.g. arcade_15), everything is fine. I hear sound coming through the connected TV. The problem is that as soon as I switch the monitor spec to "custom" no sound comes through the TV! The really weird thing is that if I pull the 3.5 mm plug from my laptop I can hear the sound coming through the laptop speakers. If I use a preset monitor spec I can hear the sound through the TV or laptop speakers, according to whether my audio cable is plugged in.
I find this really strange and don't know what's going on. :( Obviously I want to have the sound routed through the TV's speaker but I'd also like to fine tune the picture using a custom setup.
Any clues as to what's going on?
My MAME/SCART/CRT blog: SCART Hunter
Calamity
  • Moderator
  • Online Online
  • Last login:Today at 11:19:48 am
  • Quote me with care
Re: Audio issue with Lenovo laptop using custom monitor specs
« Reply #1 on: July 31, 2014, 07:17:57 am »
Have you seen if GM is accepting your custom crt_range properly? Check your logs, maybe if the format is wrong it could be causing an undefined behaviour. I can't think of a possible link between crt_ranges and audio, to be honest.
Steps to create a log:
Paradroid
    • SCART Hunter
« Reply #2 on: July 31, 2014, 08:33:05 am »
Okay, I've attached my logs. One is running mslug with the "arcade_15" preset and the other is using my "custom" monitor spec.
I can confirm that sound works fine with the preset but not with the custom spec.
It's so strange because if I pull the audio cord out with the game is playing (using "custom") the sound plays through the laptop speaker.  ???
Calamity
  • Moderator
  • Online Online
« Reply #3 on: July 31, 2014, 09:12:52 am »
Your logs look fine. Just to test random things, try enabling -frame_delay with whatever value (1 to 9).
