Author Topic: Mame Not Working - Zig Zag pattern???  (Read 1391 times)
kaptainsteve
  • Last login:November 22, 2025, 09:12:21 pm
    • Swamp-Ass
« on: July 28, 2014, 07:03:39 pm »
Hello,
I've been doing the Mame thing for a while but I just got slammed with an issue I can't get my mind around.   I just installed Mame 154 on the Arcade cabinet/pc and it won't load past a black and white zig-zag pattern?
I have no idea what the problem is and I am hoping someone could point me in the right direction?
I tried to go back to earlier versions of Mame but get the same thing with them as well?
Advice welcome.
Thanks.
Kaptainsteve
Slippyblade
Re: Mame Not Working - Zig Zag pattern???
« Reply #1 on: July 28, 2014, 08:05:20 pm »
Have you ever had MAME working on this particular hardware or is this a brand new build?  How old is the mobo involved? What kind of video are you running?
kaptainsteve
    • Swamp-Ass
« Reply #2 on: July 28, 2014, 08:32:07 pm »
Thanks...
It's an old pc but the thing is 153 has been working fine.  I install 154 and it won't load and I get the zigzag pattern.   Then I try to reinstall 153 and get the zig zag pattern.  I tried 152, same thing.   I installed Mame 148 and that works.  149 and up don't.  148 and below, work????
I did a clean reinstall and get the same thing?
« Last Edit: July 28, 2014, 08:43:55 pm by kaptainsteve »
Slippyblade
« Reply #3 on: July 28, 2014, 08:44:46 pm »
I wish I could see a screenshot.  From what I *think* you are describing I'd try using command line switches and disabling hardware rendering.  I got funky zig-zags and garbage once when I was using onboard video that didn't have hardware acceleration.
kaptainsteve
    • Swamp-Ass
« Reply #4 on: July 28, 2014, 08:57:50 pm »
Here's almost exactly what the screen looks like...
Slippyblade
« Reply #5 on: July 28, 2014, 09:06:16 pm »
Yep - that's what mine looked like.  When you had it running on other versions were you going through a front end or batch files or running directly from the command line?
Try this...
mame.exe <gamename> -video <gdi|ddraw|d3d|none>
Start with the gdi switch.  That's the crappiest, but most compatible.
kaptainsteve
    • Swamp-Ass
« Reply #6 on: July 28, 2014, 09:18:50 pm »
I went and changed the video setting in the ini file to "0" and that fixed it!!
Whewwwww...
Thanks.
