Author Topic: HELP: Original Asteroids Cab Fix  (Read 1542 times)
gargoyle73
  • Last login:September 08, 2021, 12:54:20 pm
« on: July 22, 2014, 03:46:20 pm »
Hey there all, good to be back!
I am helping a friend get an all original Asteroids cab repaired after a few years of clean running, and could really use suggestions.
ISSUE: marquee lights come on but NO screen action or button lights
I assume try res-seating the pcb?  check power board connections?
In honesty, I'd like suggestions for 'bullet-proofing'/updating cab to get flawless performance?
Thanks so much!
Lee
RandyT
    • GroovyGameGear.com
Re: HELP: Original Asteroids Cab Fix
« Reply #1 on: July 22, 2014, 05:31:29 pm »
Marquee lights on original games are usually run straight from the 110v source, so that sounds about par for the course.   It's not playing "blind", so the monitor can probably be removed from the equation.
Check any and all fuses for continuity (power off, of course) and if they are good, see if the power supply is putting out the correct voltages.  It may all check out fine, but it's where I would start with a "dead" machine.
paigeoliver
  • Awesome face!
« Reply #2 on: July 22, 2014, 10:50:27 pm »
You need a multimeter. Without one you can test essentially nothing.
Asteroids can also be a difficult first game to fix up and there isn't a huge price swing between a dead one and a working one, just keep that in mind.
« Reply #3 on: July 23, 2014, 11:19:16 am »
... see if the power supply is putting out the correct voltages.  It may all check out fine, but it's where I would start with a "dead" machine.
This, check it with a multimeter.  This video below is very detailed and may help you out.
For an older power supply watch this video:
D
« Last Edit: July 23, 2014, 11:32:53 am by DeLuSioNal29 »
gargoyle73
« Reply #4 on: July 24, 2014, 10:27:47 am »
Thanks everybody, multimeter in hand and going to check soon, will keep you posted!
Lee
