Author Topic: Lindbergh Universal Panel Size?  (Read 1495 times)
srarcade
  • Last login:June 18, 2018, 03:16:29 pm
« on: July 22, 2014, 12:16:09 pm »
Does anyone know the dimensions of the Sega Lindbergh control panel (drop in steel portion with sticks and buttons) for the universal cabinet? Trying to create a design to re-use this panel and I do not have one to measure.
EDIT - Based on a picture of the CP, if the holes are 30mm, I can approximate the width of the panel to be roughly 695mm and height 135mm. If anyone can confirm this, I am set!
Thank you
« Last Edit: July 23, 2014, 12:08:14 pm by srarcade »
